Question about Watches
Setting up roots R635 watch on the led movement
How do i set my digital watch,roots ry2129
Here is an actual 'live' web link (I just checked) - to Roots, "watches":
http://usa.roots.com/on/demandware.store/Sites-RootsUS-Site/default/Search-Show?q=watches&simplesearch=
If nothing else, if you scroll to the bottom their contact info appears which I am also pasting below. Good luck to you!
Contact Us:
• 1-800-208-0521
• Outside of Canada: 1-972-265-4120
• Email: onlineservice@roots.com
Nov 09, 2014 | Watches
Intercrew LED watch, model ic3905. How do I set time and date?
Setting intercrew led time and date - Fixya
www.fixya.com/support/t14276175-setting_intercrew_led_time_date
Sep 8, 2012 - setting intercrew led time and date no instructions to set time and date on LED Watch by INTERCREW - Watches question.
Intercrew LED - YouTube
? 1:57
https://www.youtube.com/watch?v=bR9oGWDTwxs
Jan 25, 2012 - Uploaded by CoolWatchDanmark
Review af et af vores meget popul?re LED-ure. Intercrew LED. ... ????????
Dec 24, 2013 | Watches
I have a mickey mouse watch and I can't set it. It is running. It is a Lorus with the numbers vg91 6000 Z0 call 256-757-1533 Thanks
If any analog watch will not set and it is running, most likely the set wheel (gear) of the movement is damaged and the entire movement must be replaced. The wheel alone is not possible to replace.
I recommend visiting or contacting your local Certified Master Horologist to attain what is usually a free estimate or quote on the replacement of the movement.
Feb 23, 2011 | Disney Watches
How do I change the time on my Citizen Alarm Chronograph WR 50 watch?
First we need to determine what movement is in the watch.
Look on the back of the watch. You will see some numbers there will be a 4 digit number followed by a dash and 6 or 7 digit number.
The 4 digit number is the movement number. example e760 or b210. Ctizen has hundreds of them.
Next click on this link:
http://www.citizenwatch.com/COA/English/settings.asp
enter the movement number and click on get setting instructions.
Nov 07, 2010 | Citizen Watches
How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder.
Apr 04, 2010 | Watches
Need switch settings for Steinhausen watch winder to suit an Omega Coaxial movement. I do not have the original manual, and I cannot tell how to set the switches to get the appropriate winding action for...
Leave the settings as for ordinary automatic movement. Co-axial movement has nothing to do with winding process - it was developed for more precise time keeping and friction reducing only, so, you can wind the watch in winder as usual.
Mar 26, 2010 | Watches
Bijoux Terner ''Sport'' digital watch, model R0803M. Module appears to be WR30M. Setting sequence seems to be messed up...
If you are having trouble setting the watch there could be an issue with the movement itself! I suggest taking to a watch repair business and having them take a look. If the movement is bad it shouldnt cost too terribly much to replace it.
Jan 08, 2010 | Watches
The hands don't work?
Check out if you have two batteries in your watch - one for LED display, another for analog movement.
If there is only one battery, your watch has a mechanical fault and you will need help of a watchmaker.
Rate, please.
Jul 28, 2009 | Timex Expedition 84601 Wristwatch
I have a Citizen Blue Angels Skyhawk Watch for Him. For the life of me, I can't figure out how to set it to my Eastern time. It's a cool watch but a bear to set!
What is the movement number of the watch? It is a 4 digit number/letter on the back. (something like xxxx - ####### - HST where xxxx is the movement number (or calibre as citizen calls it)
Find your calibre number:
http://www.citizenwatch.com/COA/English/identifycaliber.asp
Citizen has tutorials on their web site as well as manuals. You can get it by entering your movement calibre here:
Apr 09, 2008 | Watches
Watches Logo
44 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
