Question about NAD L40 CD Player
High pitch sound even with speakers disconnected
My NAD L40 is about 5 years old, and it works fine, but since a month or so it has been making a high pitch sound whenever it is turned on, the sound is not very loud, but it is annoying. I have even unplugged the speakers and everything connected to the receiver (aux input), and the sound is still there. This is regardless of the input (CD, AUX, TAPE, TUNER).
Thanks.
  • Anonymous Nov 15, 2008
    i have the same problem!
Hi Naduser,
I hav had the same problem (probably). It is a smal chopping powersuply to power the backlight of the lcd-display. It's a small pc-board mounted at the rear of the cd-cabinet, just next to the mains-power-transformer. It can be easyiely disconnected by unplugging the 3-pole connector from the mother-board, and the sound will be gone. However the display readout will faint down then, but its still readable. The higher serial-numbers don't have this problem, so an exchange of the small pc-board might be the best solution.
Succes, Hildert
Posted on Feb 03, 2008
    Sniper:
  • 108 Answers
1.the problem with your audio processing circuits and improper power filter
2. Check audio amplifier coupling capacitors
3. Rectifier capacitors
4. contact service centre
Posted on Dec 22, 2007
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
When I went to turn on my 20 month old 46in LCD LN46A500 it made the loudest high pitch screeching sound that no one would like to hear and the picture was black. The remote buttons and the TV control...
The power supply board have fail badly,all that high pitch screeching sound,it came from those high voltages gaps from those tranformers,that giving ur tv high voltages.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Samsung LN46A500 46 in. TV
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Samsung SlimFit 30" high pitch whining noise
I have had the same high pitch tone problem for several months after about 20 minutes of use. It is so bad it's rendered the TV almost unwatchable. I contacted a repair place from Samsung's website. I was told that is likely the flyback transformer. I don't know what it is, but it sounds cool like a flux capacitator. I was told it would be about $100 to fix. However, I have had very little luck getting the repair shop to order the part and do the work.
Sep 04, 2008 | Samsung TXR3079 TV
Nad c520 high pitched ringing
Hi, From your description, it sounds as if the noise is coming from the circuit that controls the display backlight. If I recall correctly, the C520 has an EL backlight just like the C521 (which I have one of). On the front of the circuit board, there should be a little yellow trimmer potentiometer that controls the brightness of the display. It may be that the noise will go away if the brightness is turned down some. If  the noise varies as you turn the controller, but doesn't go away completely, the backlight may need servicing.
Aug 06, 2008 | NAD C521 CD Player
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Jun 04, 2007 | RCA 27R410T 27" TV
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
NAD L40 CD Player Logo
304 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
