Question about Etymotic Research Ety.Kids5 Ek5 Earphones - Surround -
Unit earphone housing is cracked
4x4. How can I replace cracked front differential housing?
jack the vehicle up and put on stands
remove the diff housing as a complete unit
depending on where the crack is it may be possible to have the housing welded up by an accredited engineering shop and if possible have the area properly reinforced to prevent it cracking again
Feb 23, 2016 | 2003 Ford Explorer Sport Trac
Why no sound from my laptop audio jack
make sure the driver is correctly installed
Apr 30, 2014 | Toshiba Satellite Computers & Internet
Wire disconnect from left earphones
Time for some ingenuity.Disassemble the housing to get to the wire connections.The solder pads where the wires go are usually marked + or minus(-). The white/colored wire(signal) goes on the + side.This could be a red dot. The other wire (black) goes on the other pad(-). These wires are so fine they sometimes use nylon thread to give it a lil strength.Good Luck! dnbbgy
May 30, 2010 | Bose TriPort Consumer Headphones
Hard to hear - maybe dust in speaker? How to clear
As you mentioned dust may be one problem.To rectify this go to your nearest Nokia Care center & service the phone.
The problem may also be due to the low earphone volume.Please check your earphone volume to rectify this.
There is also a possibility of minor damage in the earphone unit due to which your not able to hear properly. You have to replace the earphone unit in this case.
Feb 25, 2010 | Cell Phones
I purchased this LCD TV almost 1 year ago and have been using it for about 4 months. I have a reoccuring problem w/ the sound not working at all. It seems to just happen, nothing different being done to...
check out if it had a earphone out, if there is, got a earphone plug to it, if theres a sound being heard at the earphone, a loose at earphone jack is the situation....
Dec 31, 2009 | Sharp 32SC260 32 inch TV
My earphones won't work
Usually this is a problem with the wires in the earphones themselves actually being broken or the connection on the earplugs is too small. I suggest borrowing another pair of earphones to make sure the problem actually is in the Zen. If another pair works, you know the issue is the earphones. If the problem remains even with different earphones, take a look in the earphone jack hole to make sure nothing is stuck in it like paper or something. If everything is clean, the earphone jack or its soldered connections inside the Zen may be cracked and will require the unit to be opened and serviced.
Aug 17, 2009 | Creative Labs Zen Micro MP3 Player
Itouch loudspeaker, earphones?
No just the models with that feature have the loudspeaker. my girlfriends sisters ipod touch doesnt have it either. I hope that helps you out.
Dec 31, 2008 | Apple iPod touch
No Volume
The earphones input are in bad conditions you need to change it,or try put in the earphones and put out until the picture of the earphones go out.
Aug 17, 2008 | Samsung HLN5065W 50" Rear Projection...
Touch Screen Creacked, but LCD is fine.
Hi Parvinder I suggest you replace the touchscreen though the procedure is not easy but I can provide you the instruction for how to replace it. If you can follow carefully the instruction of how to replace it, you will have a nice screen again. Please send your email to my address below: joe_dao2003@yahoo.com I will reply to you the full instruction written by me included of how to diassemble the unit. This model is also called audiovox xv6600, Siemens sx66, Qtek 9090.. but thet has the same housing with some modification but my Service Guide can be applied for all. You can buy the touchscreen only on Ebay for $19.95. Regards, pingping
May 22, 2007 | Orange SPV M2000 Pocket PC
Etymotic Research Ety.Kids5 Ek5 Earphones - Surround - Logo
22 people viewed this question
Top Etymotic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Etymotic Audio Player and Recorder Expert? Answer questions, earn points and help others
