Magnadyne rv5090 linear series remote code
Do you know what the remote control code for this unit
2 Suggested Answers
Sparky-UK
  • 129 Answers
SOURCE: Remote Code Disk VIP622 to Control Bose 35 SeriesIII
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3021
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
Need wiring diagram pin out for a magnadyne
not sure what model magnadyne ,follow this link for more info and manual download
Download Magnadyne M9900CDS Installation And Operations Manual
May 14, 2014 | 2010 Toyota Land Cruiser
My old feedback unit has a red,white,and black wire. my new unit has a red, blue and green wire. how do i attach my new wires?
If you run the wire to the CPU the color code is on the CPU. If it is a ST5000 series product the wire would need to be run to the back of the control head. Both the CPU and the control heads are clearly marked for the color codes.
May 31, 2010 | Raymarine Linear Feedback Unit For...
I'm getting an error code of W8102. Can anybody out there tell me what that means??
W8101/8102 - Print media position warning
The paper over the platen lies too near or too far from the carriage home position
when fed into the printer.
Cause>
The paper on the platen was too close to or too far from the carriage home position
side when paper was fed.
<Probable faulty component>
The way in which paper is set, print paper, cassette/cut-sheet feed unit, carriage
unit, encoder sensor unit, linear scale, carriage controller, head controller, system
controller.
<Action>
1. Paper setting check:
Reset the paper if the setting is not correct.
2. Paper check:
Replace the paper when any stains or pre-prints are found.
Straighten or replace the roll media when the roll of paper is ruffled.
3. Cassette unit/cut-sheet feed unit:
Replace the faulty paper feed component when the paper feeding is performed
correctly in all parts except where the error occurred.
4. Check the linear scale:
Visually check the linear scale for abnormal conditions, such as stains or damage.
5. Replace the carriage unit.
6. Replace the head controller.
7. Replace the system controller.
May 18, 2010 | Canon BJ-W9000 Copier
I need the code to disable to parking break to watch my dvd's while driving with my jensen phase linear uv9
you will need the remote control to do so.
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
Aug 17, 2009 | Phase Linear Car Audio & Video
I have the phase linear UV7i I was trying to put in the overide
reset it,try with out the remote and change the remote battery,put in dvd wait for the blue screen,then press stop 2x then enter 1264 then,if you have a up,down,l/r control on the deck press down 1x then press play,you dont even have to use the ground wire then go to the rest, when you can see the menu,i dont know if it will work but u can give it a try
Jun 18, 2009 | Phase Linear UDV9010 Car DVD Player
Need to know what p1188 is to diy er
SAE Code P1188 DTC Code 17596 Description Linear 02 Sensor / Compensator Resistor Short to ground SAE Code P1189 DTC Code 17597 Description Linear 02 Sensor / Compensator Resistor Short to B+ SAE Code P0170 DTC Code 16554 Description Fuel Trim, Bank1 Malfunction
Basically you need a new oxygen sensor, The fuel trim code is from the computer trying to adjust the fuel/Air mixture to compensate for the bad signal from the sensor. Just change the one closer to the engine, the one behind the Catalytic converter will thow a different code when it fails.
Dec 07, 2008 | 1999 BMW 323 Series
Remote codes for a urc - 4640B00 one for all , can you help?
Your unit is a discontinued unit however you may click on the link below for remote codes for the 4600 series.
http://www.hifi-remote.com/ofaold/acc3cod.html
Nov 22, 2008 | One For All URC-3021 Remote Control
Programming code for remote control jensen jr321
I am not 100% positive that the JR-321 is supported in the 300 series but.
Jensen JR300 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps!
Oct 03, 2007 | Jensen JR500 Remote Control
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
Electro Med Services...
