Question about Flip Video SlideHD S1240W HDMI Camcorder
Flip s1240 how do you charge - Flip Video SlideHD S1240W HDMI Camcorder
How long does the JBL flip take to fully charge
On the WEB:
Charge JBL Flip Speaker‎
www.wow.com/Charge+JBL+Flip+Speaker‎
Search for Charge JBL Flip Speaker
Jul 30, 2015 | JBL Audio Players & Recorders
I have a flip slide hd S1240W that has not been charged up in a long time. I have tried to charge it and attempted to reset and then charge. All that is happening is a red flashing light but nothing at...
Try removing the batteries, plugging into your computer, popping the batteries back in, and removing. Wait 5 minutes, and plug back in! This should have an affect!
Oct 06, 2013 | Flip Video SlideHD S1240W HDMI Camcorder
Flip Camcorder Model S1240
Since you have already tried the reset then you are done, nothing else can be done to fix this issue, it is a battery problem The batteries are integrated to the internal circuit CCD board and are not replaceable. If I had the camera I would do my best to take it apart and find out what type of battery it uses and then go to eBay and find the correct cell type and replace it. But unless you are very mechanically minded I would not recommend the trouble.
Jun 21, 2017 | Flip Video Video Cameras
My Flip Ultra HD has a red light that blinks when I try to charge it. It won't charge, what can I do to charge it?
Make sure you use a good USB 2 port and make sure your computer stays turned ON during the charging or it will not charge. The red light should stay on on the front of the camcorder while charging and will go off when charging is complete.
Try a different USB port maybe also. or if using a USB extension make sure it is a powered extension, and if not, connect the camcorder directly into a USB instead of using an extension.
My extension has a light to show that it is a powered extension.
Jan 31, 2011 | Flip Video Flip UltraHD 8GB High...
My flip mino HD has been charging for 3 hours and will not turn on. I've tried resetting the battery and it still won't turn on
Is it plugged in directly or with a USB extension cable? Some cheaper cables are not sufficient to charge it.
Mar 18, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip videp ultra hd - red light blinking while charging
i have the same problem too. whenever i try to charge it through the dock. the red light continuously blinks and it won't charge.
Aug 22, 2009 | Flip Video Flip UltraHD 8GB High...
Flip Mino won't turn on!
I had the same problem. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
Feb 03, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip video won't charge
If you look on the bottom of the camera there is a button that slides from a locked to an unlocked position. Slide it to unlocked and then slide down the back of the camera (the side with the lens) there is a removeable rechargeable battery pack. Remove it for a moment and then put it back in. Try plugging back into the USB port. This should work.
Jan 09, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Video SlideHD S1240W HDMI Camcorder Logo
Top Flip Video Video Cameras Experts
matt
matt
Are you a Flip Video Video Camera Expert? Answer questions, earn points and help others
