Police Skyline-X Watch Logo
A
Anonymous Posted on Feb 10, 2014
Where to change watch strap in singapore ? - Police Skyline-X Watch
Where can I get a replacement strap
You can remove the strap yourself. Instructions with pictures here.
http://www.watch-straps.ru/2011/07/02/how-to-change-watch-strap/
Feb 22, 2015 • Watches
How to change leather strap
You may follow this link on youtube which explains exactly how to change a leather strap: http://www.youtube.com/watch?v=TtPde-M5Xz0
How to change the watch strap, resin type
One way to change a watch strap, is if you have any old watch straps you can use them. There should always be a bump by the actual clock. You should be able to manuever the watch out of the two small holes by using your fingers. You can then interchange watch straps!
2answers
My diesel DZ1131 watch's strap has broken for the second time ina row..i wou like to replace it with metal starp....would it be possible///
Unless the watch has a unique design on lugs for the strap, you should be able buy a strap that is interchangeable with the existing one form most watch shops.
They will usually fit it for you for nothing.
2helpful
4answers
Cerruti watch strap cannot be changed in any watch specialists in middlesbrough and i am just wondering where i will be able to get it done
You probably will have to send it away to get sorted (make sure you send it insured and very well protected).
You should contact cerruti to see who the repair shop is in the UK, (not sure they have one.)
Failing that you may be able to buy a replacement strap of ebay and have a general watch shop change strap for you.
Or find a jewellers that sell straps, they should have one that fits.
Please dont forget to vote if you liked my answer
thanks
35helpful
How to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
4helpful
Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
3helpful
Can't figure out how to change watch strap
Hi, try this - it worked for me. Use a needle to poke the ends of the watch strap axel (at the end and running across the strap). This should then allow you to lit the silver panels at the top and bottom of the watch face off. The axel should then slide out. I did this by pushing one end of it through with a needle so that the other end poked out enough to pull it out with a paid of pliers.
2helpful
Fossil watch service centers in India
Need to change leather strap
Dec 12, 2007 • Watches
Top Police Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Police Watch Expert? Answer questions, earn points and help others
