Question about Ovens
Clean between glass on Westinghouse model pdp790s#02
I have the above double oven and wish to clean between the glass doors
  • 833 Answers
SOURCE: jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Posted on Dec 07, 2007
Krazytech
  • 725 Answers
SOURCE: DCS double wall oven model WOSD 230 totally dead during first self clean
let me know if you don't get the solution... thanks
Posted on Sep 28, 2008
onthejob5130
  • 640 Answers
SOURCE: cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Posted on Dec 27, 2008
  • 17 Answers
SOURCE: cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Posted on Feb 04, 2009
  • 43 Answers
SOURCE: How to clean inside glass on oven door
If you can, usually it is possible, remove the door from the oven. open door to the first open position..(broiling) about 6" open then (make sure any screws are removed from hinges holding door in place) lift up and out at the angle the door sits.place on counter and start removeing screws. can be a whole bunch of em..
Posted on Oct 25, 2009
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
Queries
You could use a dishwasher if you remove the glass panels. I would be leery of breaking the glass panels. They are not cheap, be careful.
Mar 27, 2014 | Electrolux EOD5330 Ultrafan Electric...
How do I clean between the glass on my electrolux double oven model EDEE63AS*41
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Sep 10, 2012 | Ovens
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
How do i take the door off to clean it
To take the door off you have to remove inner glass panels from both doors. Then remove the appliance from the housing unit. When the unit is out, you then have to unscrew the top panel and both side panels and lift them clear.
With the door closed, support it with one hand as you carefully unhook the large springs from the door hinge arms. The door frame can now be removed.
The above is from the handbook. You can actually remove the outer glass panel as well but personally would just slide the inner glass panel out and clean the door in situ.
Feb 06, 2010 | Stoves 720EF Electric Double Oven
How to clean between doors of a wall oven a
2smart4u did not answer the question - how to clean between the glass on the oven door. I too have streaks inside the glass - looks bad - no way to clean it?
Dec 04, 2009 | Ovens
Cleaning between double glass oven door
Feb 04, 2009 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Jenn air double ovens
Oct 30, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
