Question about HP LaserJet M9050 MFP Printer
Reinsert duplexer Printer says" Reinsert Duplexer"
  • 186 Answers
SOURCE: Duplexer problem
First, the machine always prints the first page first. Make sure you have the right driver (4 plus and not 4)and check the settings in the device settings of your printer driver on the pc. Also make sure the duplex unit is for the 4 plus and not the 4.
Posted on Jun 21, 2007
SOURCE: Problem w/ Duplexing Attachment on HP PhotoSmart P1100 Printer
Maybe this would help:
Open the access door on the duplexer and clean the rollers with a damp cloth. If that solves the problem, I suggest using rubber rejuventator as a long term solution.
Posted on Nov 15, 2007
IB4G2008
  • 3587 Answers
SOURCE: HP LaserJet 4700DN Duplexer Jams
hmmm..check the paper for riffling(with fingers before placing in tray)..and the rollers can get slippery, after a period of time...
check your computer warranty for FREE here
Posted on Feb 22, 2008
SOURCE: Paper jams only while duplexing
is your paper tray set for custom size paper
Posted on Apr 04, 2008
SOURCE: Cannot get printer (hp C7280) to print double sided
There is a new driver from april 2009 on HPs site which adresses this problem. I installed it, and now everything works fine. You have to download and install it yourself, it doesn´t update automatically.
Posted on May 07, 2009
How do I get jammed paper out of the back of it?
This is from the user guide available on the HP.com website:
This section contains the following topics:
• Clear paper jams
• Avoid paper jams
Clear paper jams
Paper jams can occur either inside the printer or in the automatic document feeder.
CAUTION: To prevent possible damage to the printhead, clear paper jams as
soon as possible.
TIP: If you notice poor print quality, clean the printhead. For more information, see
Clean the printhead.
Use these steps to clear a paper jam.
To clear a jam inside the printer
1. Remove all media from the output tray.
CAUTION: Trying to clear a paper jam from the front of the printer can
damage the print mechanism. Always access and clear paper jams through
the automatic two-sided printing accessory (duplexer).
2. Check the duplexer.
a. Push the button on either side of the duplexer, and then remove the unit.
b. Locate any jammed media inside the printer, grasp it with both hands and
then pull it towards you.
c. If the jam is not there, push the latch on top of the duplexer and lower the
cover. If media is jammed inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the printer.
3. Open the top cover and remove any debris.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and
remove the jammed media, if possible. If not, do the following:
a. Ensure the printer is turned off and disconnect the power cord.
b. Lift the printer off Tray 2.
c. Remove the jammed media from the bottom of the printer or from Tray 2.
d. Reposition the printer on top of Tray 2.
5. Open the ink cartridge access door. If there is paper remaining inside the printer,
ensure the carriage has moved to the right of the printer, free any paper scraps or
wrinkled media, and pull the media towards you through the top of the printer.
WARNING! Do not reach into the printer when it is on and the carriage is
stuck. When you open the ink cartridge access door, the carriage should
return to its position on the right side of the printer. If it does not move to the
right, turn off the printer before you remove any jam.
6. After clearing the jam, close all covers, turn on the printer (if you turned it off) and
resend the print job.
That's about as much as I can find for you. If you look in you user guide which is on a CD that came with the unit, you can go to page 152 through 154 to see diagrams that go with these instructions. Good luck!
Nov 13, 2014 | HP CM749A - Officejet Pro 8600...
I have a 69.0 printer error on my HP5100dtn printer.
Hi Mary L,
Good day... This steps may be helpful for you. try sorting one by one steps...below
solution 1:
1.The duplexer side adjust has failed.
2. Turn the printer off and then on.
3. Reseat the duplexer assembly.
4. Replace the duplexer assembly.
solution 2:
1. The duplex printing unit is not functioning.
2. Turn the MFP off, and then turn the MFP on.
3.Reseat the duplexer.
4. Check the connection between the duplexer and the DC Controller.
5. Replace the duplexer.
solution 3:
1. Duplex mechanism failure.
2. Duplex slide adjust has failed.
3. Temporary error.
Hope this solve the problem...
Thanks in Advance.
Hp Error Code 69 Service Errors 69 Printer Repair Message
Sep 15, 2017 | Office Equipment & Supplies
How to print double sided on an epsom 580 printer
From what I can see, this printer does not have a duplexer tray. Thus, you must manually print two-sided. To do this you need a print spooler than will support this by printing the even pages, then after you flip the pages and reinsert them, print the odd pages. This works well unless there is a double-feed, because then all pages after that are out of sequence. It is best, when manually printing two-sided copies, to do them in small batches to avoid waste id your printer is prone to skips and double-feeds.
Aug 24, 2014 | Office Equipment & Supplies
How configure duplexer dell 3110 cn?
You don't really need to configure it as such.
The printer should recognise the duplexer if it is fitted correctly, and it's difficult NOT TO.
Printing a settings page will show the duplexer under Printer Options.
You printer driver needs to be aware of the duplexer, there is an option to 'get information from printer' within the Windows driver.
Once the driver knows the duplexer is available, you'll have an option in the printer driver to print double sided.
Apr 30, 2014 | Dell 3110cn Laser Printer
My hp 8500 is saying paper jam but there never was one
Hi, please try this:
a. Push the button on either side of the duplexer, and then remove the panel or unit.
b. Locate any jammed media inside the device, grasp it with both hands and then pull it towards you.
c. If the jam is not there, push the latch on the top of the duplexer and lower its cover. If the jam is inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the device.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and remove the jammed media, if possible. If not, do the following:
a. Ensure the device is turned off and disconnect the power cord.
b. Lift the device off Tray 2.
c. Remove the jammed media from the bottom of the device or from Tray 2.
d. Reposition the device on top of Tray 2.
5. Open the print carriage access door. If there is paper remaining inside the device, ensure the carriage has moved to the right of the device, free any paper scraps or wrinkled media, and pull the media towards you through the top of the device.
6. After clearing the jam, close all covers, turn on the device (if you turned it off) and resend the print job.
This is based on the HP 8500 manual. I hope this helps.
Aug 22, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Paper does not feed straight into printer and causes a paper jam
You have to remove all the paper from your Printer. Press and hold the "Power" button on your printer's front control panel to power off the device. If you locate the duplexer on the rear of your printer, then press the release tab to remove it. Check to see if there is any displaced paper within the duplexer. Pull on any trapped paper and remove it from the printer. Discard then the paper and snap the duplexer back into place. The last thing you have to do is to reinsert the paper back into the printer's paper trays, and power on the device. If you want to see if it works, print a page.
Here is a video which will explain how to resolve this paper jam problem.
I hope I helped you!
May 14, 2011 | HP Officejet 6500 Wireless All-in-One...
I put in new cartridges and the orange light keeps blinking
If that's the access foor at the back of the printer might just be loose or unlocked. Try locking the door into place and see what happens. Or if you have a duplexer. Try these:
  1. Press the buttons on each side of the duplexer to release it. Figure 7: Press the buttons to release the duplexerc02622982.gif
  2. Remove the duplexer from the product.
  3. Reattach the duplexer. Press the buttons on each side of the duplexer, and then gently push the duplexer back into the rear of the product until it snaps firmly into place. Figure 8: Reattach the duplexerc02622983.gif
  4. Repeat the steps to reattach the duplexer if the lights remain on.
    Link: HP Deskjet 940c Printer - Blinking Lights
Feb 04, 2011 | HP DeskJet 940c InkJet Printer
The duplexer in our HP printer appears to be jammed. where is it located?
As you face the printer, walk around to the left side. You will see the power switch. Above the power switch is the duplexer. It pulls out.
You said the duplexer is jammed, so you might not be able to pull it out.
Is the duplexer jammed or is there paper jammed in the duplexer?
Dec 03, 2010 | HP LaserJet M5025 MFP Printer
Duplexer problem
May 17, 2007 | HP LaserJet 4 plus Printer
HP LaserJet M9050 MFP Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
