Question about Electrolux Dishwashers
Dishlex global 450
Top tray slides are broken and needs replacing
SOURCE: dishlex 450
I had this problem and reset the dishwasher to solve. Turn off dishwasher for at least 20 seconds, turn on while pressing eco button and wait for about 30 seconds. Should hear beeps.
Posted on Jul 21, 2008
SOURCE: Top Tray clips on diswasher broken
I have the same problem and there is an inherent design flaw. You can normally buyt these at most outlets, however you can buy more than 4 to support the tray, or I have cut a small diameter aluminium tube (1/4" diameter) and threaded it through the tray from the side and into the sliding rails. It is not an ideal solution, but will last a lot longer than the silly grey wheels! Doi two bits ( one at the back and one at the front.) You have to play around a bit to get the drawer to move in and out, but it is much stronger than before. Good luck Charles in Australia
Posted on Oct 05, 2008
SOURCE: Dishlex Global 300 - stopping mid cycle
This problem is common to both the 300 & 310 models. The flashing Fast light indicates a blockage in the water supply. I fixed this by:
- disconnecting the dishwasher
- checking for blockages in the input hose filter (there were none)
- removing the bottom of the dishwasher (two screws at the front)
- looking for the translucent plastic bucket thing attached to the side of the main assembly
- unclipping it from the main assembly and removing the white hose attached to it
- flushing 5 years worth of evil gunk down the sink (you need a small brush or piece of wire to get it out
Gabriel
Posted on Jul 28, 2009
  • 574 Answers
SOURCE: Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Posted on Jan 25, 2010
SOURCE: Replace bottom door seal on Dishlex Global 300 Dishwasher - Model DX300SA
HI - i just replaced the bottom seal yesterday. The guy at the spares shop advised me to replace both (bottom of door and bigger seal ) at the same time to ensure no leaks - i did that. The bottom door seal come out when you unscrew the screws - (No need to remove door) and because of all the gunk (from years of washing and age of the rubber) i had to wedge a blunt knife in between (starting at one of the ends) and lever it out - MAKE SURE YOU TAKE NOTE OF THE WAY IT IS BEFORE YOU REMOVE IT! An easy way to remember is there is a nick in the rubber of the old (and new) seal and as it is not centred, just note if the nick is closer to the left or right of the machine, I have replaced mine and there is a little leak and now i wonder if i put the seal in upside down! it has to go in the same way - before you gimmy your's out can you tell me if the nick in the rubber is to the left or right? (LIZ at yodelayeeoo@gmail.com) If I have put in back right there is a chance the screw didn't go through the plastic part of the seal and therefore not holding it in place properly. GOOD LUCK! Don't worry about having to really work at getting the old seal out - you don't need it anymore and i didn't damage mine, regards, Liz
Posted on May 27, 2010
We have a global 450 dishwasher cannot find probes
Contact Dishlex direct using the link below. We are a North America website, and your machine is a an Electrolux Australia version.
Troubleshooter
Mar 29, 2018 | Dishwashers
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
I have a dishlex global 450 it is displaying two backwards c's any ideas is there a fuse or anything....thanks
Hi
I do not recall this being a valid fault code.
If nothing at all works, it sounds like a faulty control board.
I hate to say it, but with the age of a Global 450, it may be more economical to replace the dishwasher.
Generally the board is quite expensive, and as the global series are quite loud and power hungry, it might be a good excuse for an upgrade.
Adam
May 29, 2013 | Dishwashers
I need a free manual for the dishlex global 450. Most sites request you sign up.
Here in the state, Dishlex is the same as Electrolux. I would think the models are the same,except fort he number. Take a look.
http://www.electroluxappliances.com/kitchen-appliances/dishwashers
Oh yes here is the Australian manual download site also:http://www.dishlex.com.au/downloads.html
Hope this helps.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
Feb 20, 2011 | Dishwashers
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex Global 450
Jiggle the float in the dishwasher, turn dial or push button to cycle drain, or rince and off. Vitally
May 13, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Dishlex global 500 rinse and wash problem
This was due to a faulty pump motor which I have now replaced.
Jan 10, 2009 | Dishwashers
Dishlex 450
May 05, 2008 | Frigidaire 24 in. FDB126RB Built-in...
My dishlex global 450 dishwasher was making a humming noise all night and dispayed OF before I disconnected the power to it. Thanks Karen kar14839@bigpond.net.au
The of means the grease trap is over full or over flowing and needs to be serviced. This is best done by a qualified serviceman.
Apr 06, 2008 | Dishwashers
Dishwashers Logo
11 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
