Question about Acer Aspire 5335-2257 Notebook
I have a Acer Aspire 5735-4774 computer will not turn on just flashes yellow even if battery removed with just ac
Eddie333
  • 176 Answers
SOURCE: acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Posted on Jan 04, 2009
SOURCE: ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Posted on Feb 24, 2009
  • 82 Answers
SOURCE: Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
Posted on Apr 22, 2009
rulds2008
  • 3866 Answers
SOURCE: acer aspire 3000 won't come on just yellow light blinks
Psu failed!! your goingto need that serviced if its under warrenty you need to take it in its hard for us guru's to solve every problem without more details.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
  • 16 Answers
SOURCE: Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Posted on Aug 23, 2009
Testimonial: "Exactlt what I had been thinking!"
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
Jun 26, 2011 | Acer Aspire One PC Notebook
How do i unlock the keys on my acer keyboard
Do a hard reset: turn off computer, remove ac adapter and battery, hold down power button for 20 seconds, put battery and ac adapter back on, then turn on computer.
Feb 25, 2010 | Acer Aspire 3050 Notebook
My acer 3004wlci wont power up. when i put the fully charged battery in the yellow lights flash for 3 seconds but wont turn on & when i use the elec cord it does nothing at all.
I had the same problem. I removed the battery and just used the AC Power Adaptor. The machine powered up and ran fine. I replaced the battery and have had no problems since (2 years ago now)
Jan 31, 2010 | Acer Aspire 3004WLCi Notebook
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
ACER ASPIRE 5100 SERIES. WILL NOT DO ANYTHING. NOTHING WORKS, MOVES, MAKES ANY SOUNDS, BLANK DISPLAY. BATTERY LIGHT FLASHES WITH CHARGER PLUGGED IN. TRIED REMOVING RAM, AND HARD DRIVE. NOTHING.
the battery might be hosed up will it boot without the battery and just plugged to ac - if it wont boot from ac with the battery remover send it to acer
Dec 27, 2009 | Acer Aspire 3000 Notebook
Apr 22, 2009 | Acer Aspire 5003WLMi Notebook
Acer Aspire One Netbook ZG5 will not turn on
you should be able to press ESC to exit hibernation, or remove the battery, remove the plug, press and hold the power button for 60 sec, and reinsert battery and power and turn on. when restarted, right click on desktop, click properties, and click the screen aver tab, click the power button, click advanced, and remove the check box beside enable hibernation on the "Hibernation" tab. it shouldn't do it again
Apr 20, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire Computer Does not Turn on
The light you are seeing usually is a sign that the battery is discharged. Although you say the battery shows that it is fully charged, it is possible that the battery is fully discharged or defective. You should disconnect the battery from the pc and try powering on with the ac adapter. Although no way to per say "force reboot," removing all power sources (ac adapter and battery) should in essence reset the motherboard.
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 3680 2682 will not power up
there are some reasons laptop can't power on, try to troubleshoot.
1. Make sure that your ac adapter is working. if you plug battery and ac adapter, the battery chargin led will be orange and if the battery is full, the led will be yellow.
2. Can you power on using battery ? if you can and you can't power on using ac adapter (i assume your ac adapter is working). the problem will be your power port.
if you can't power on using battery and your battery is working ok. the problem will be motherboard.
Apr 18, 2008 | Acer Aspire 3680 Laptop
Open Questions:
acer aspire 5335-2257 replaced 4 pin power jack intermittent power, only runs with battery but barely charges. acer aspire 5335-2238. My son's friend recently asked me to take a look at his laptop because he couldn't get it to take a charge or run without the battery when plugged in. Right away I noticed the dc jack was charred and the plastic around it melted. He said the power cord "brick" got really hot, all the way to the tip where it plugs into the laptop. I know the bricks can get warm but he said it actually burned his sister. I ended up replacing the dc jack and 4 pin harness with a new one and figured this would solve the power issue. It won't get power with the original power cord and I also tried a few others that were similar. The only one that worked was an adaptor that I think went to a cordless phone or something like. The next problem was I had to fiddle with the dc jack to get the yellow battery light on. Still won't turn on without battery. The battery at this point is drained so I left it plugged in all day, at least 12 hours and the green light finally came on indicating a charged battery. The battery only charged about 8-9% and died fast. I tried more adaptors and got another one to light up the yellow battery light, again a small modem adaptor, not one with the brick. This time I left it over night and got about 12% charge. Both times the laptop turned on, booted up and ran until the battery died after about 5 min. I'm out of ideas aside from maybe a bios problem but I can't get it to stay on long enough to do anything about it. I don't understand why the new jack isn't working, it's a pretty simple install, no soldering. I looked real close at the board and didn't see any obvious fried chips or anything like that. Any suggestions would be great. I've had this 14 year old kid's laptop for almost 2 weeks trying to figure it out (I also replaced his keyboard, disc drive and cleaned it up) and he's calling me every day.
Feb 27, 2017 | Acer Aspire 5335-2257 Notebook
Acer Aspire 5335-2257 Notebook Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
