Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Mac back light - Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My computer monitor wont start up
try pulling out the power plug to the monitor and then plug back in and turn on monitor.
I am assuming you plugged the DVI cable back in to the correct port on the monitor and Mac Pro.
May 03, 2016 | Computers & Internet
Red light staying on
say exactly what it is, Apricon, what model?
is it internal or external HDD?
Oct 02, 2013 | Apricorn Computers & Internet
I have G5 PPC mac tower - power light is on, but the unit will not turn on. No fans are running. Just a bright white light on the power button.
First if side door or plastic shield is off, fans won't come on and unit won't start. Fans only run when unit is running hard and that's not always. Back to your original issue - not running, couple of things to try - first being side door and latch on back, make sure both are closed. Try restarting by holding start button on front of tower. If that don't cure it, disconnect power lead in rear for about 30 secs then try to restart.
Feb 26, 2011 | Apple Power Mac G5 Desktop
I hear the audio on my Mac Laptop but I can't see my screen or video.
Hook up to an external monitor and if you can see. If you can see on the external monitor, then it's most likely your inverter or back light that has gone bad on your laptop screen. Inverters can be replaced fairly easily, but replacing a back light is a bi.ch and most people will just replace the whole screen rather than mess with the back light since you got to do some major surgery and de-soldering to get to it.
Sep 08, 2010 | Apple MacBook Mac Notebook
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
Hi, a few weeks ago there was a bad lighting storm in my hometown. My husband was on our Mac desktop when all of a sudden lighting struk and next thing we know all our electronics where out including the...
you need to get a new power supply from a retail store that may look like this
it will cost you no more than 100 bucks and replace this in your mac
if you need more assistance to replace the power supply please contact me at wiqi546@gmail.com or leave a message here
Thnx and i hope this helps
PLease rate this solution
Jul 16, 2009 | Computers & Internet
Powerbook g4 will not turn on
pull the battery out, put it back in, plug the mac in, and hold down the power key till u hear the chimb
Feb 16, 2009 | Apple PowerBook G4 Mac Notebook
Mac book air trouble to get on
try putting they installition disk that came with your mac. then retore it.
Jan 16, 2009 | Apple MacBook Air
Hi sir/ Mm
look closely at the screen. You might have to change the lighting or shine a powerful light from the back of the screen, through the Apple logo. If you see a dim image, your problem is either with a bad "inverter" board, a bad "CCFL" light (the bulb that lights the screen), or with the logicboard itself. check back for more info if this is happening.
Jul 08, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
32 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
