Question about Saeco Talea Ring Plus Espresso Machine
Talea Water line interrupted
Saeco talea giro flashing red exclamation point
take out the coffee waste bin, on the side facing into the machine, there's a little metal bit, it's a kind of sensor.
Clean it if it's dirty with a screwdriver or some wire wool.
Have you cleaned the brew group lately?
Sep 06, 2014 | Saeco Talea Giro Espresso Machine
I have a Saeco Talea. It does not rinse and error message is prime water system. Please advise the required process. Thanks.
i think i worked this one out it is the switch where the brew group is when you put the brew group in the slot it goes into there is a switch and it can be moved which is bad because the gears won't work and position the boiler nozzle in the right place and water poors out everywhere you need to pull it apart and reposition the switch i did this 3 weeks ago and haven't had a problem i figured that i couldn't break it any more lol Download the download is the instructions on pulling it apart or just search for talea touch repair manual and download it you need to pull the brew group section apart if you move the gears make sure you have them lined up the right way when you put it back together it was relatively easy i really hope this helps :)
Mar 10, 2014 | Saeco Talea Touch 14-Cup Coffee Maker
I had a leak in the water tank of my Saeco Talea Touch coffee machine. I oredered a new water tank and received it. How to I detach the olde water tank from the outer cover of the machine and attach the...
Turn the tank assembly upside down,there are two tabs you need to unclip to allow the cover to slide off.
One tab is near the water outlet and the other is towards the outer edge of the tank.
Jan 26, 2013 | Saeco Talea Giro Espresso Machine
How to install a new water tank in Saeco Talea?
two clips under the water tank hold the outer cover on.
Unclip,remove cover,fit cover to new tank.
Jan 25, 2013 | Saeco Talea Giro Espresso Machine
My Saeco Talea Giro have the wave like symbol with three parallel lines is flahing red. What is wrong and what can I do to fix it.
It is saying..it's time to descale the machine. If you want to get rid of it, just press the water button and hold it for 5 secs.
Jan 30, 2010 | Saeco Talea Giro Espresso Machine
Talea giro plus. csan't exit descale cycle
Keep pressing the water button for 6 secs until the flashing light goes off.
Jan 16, 2010 | Saeco Talea Giro Espresso Machine
Saeco Talea Ring Plus: often, water flows out of of water steam
The valve parts need to be replaced, if it is only happening when brewing coffee then there is so much pressure on the pump that it is forcing the valve open. First try adjusting the amount of coffee be added to the chamber for brewing.
Aug 23, 2009 | Coffee Makers & Espresso Machines
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Talea Ring Plus Espresso Machine Logo
13 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
