Question about Janome DC3050 Computerized Sewing Machine
Anome DC3050 not picking up thread
My Janome DC 3050 bobbin refused to pick up the sewing thread. This was after having refilled the bobbin, I had been sewing without problem for an hour previously. I have used a different bobbin, re-threaded the machine with different cotton, and changed the needle, without success.
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
Mimito7
  • 128 Answers
SOURCE: machine will not pick up bobbin thread
Sounds like your needle is in too far and it not allowing the needle to go down far enough to pick up the thread.
Posted on Apr 20, 2009
mohammed387
  • 1952 Answers
SOURCE: Janome sew mini will not pick up bobbin thread
Oil the machine first. Then, determine whether or not you need any parts at all.
Posted on Jul 03, 2009
Mongo32
  • 111 Answers
SOURCE: janome mini not picking up the bobbin thread!
needle in backwards?
Posted on Aug 23, 2009
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
How do I download a free manual for janome flair dc3050
Hello Rayu,
Visit this link to view the Janome DC3050 manual: http://www.manualagent.com/janome/dc-3050/users-manual
You may also find the below video useful:
Feb 27, 2015 | Janome Sewing Machines
Have Janome DC3050. Bobbin thread is getting caught on the hook shaped guard to the right of the bobbin. Hook race? I know threads got caught in bobbin and believe it bent or moved this. Now makes a...
I don't know your model but my Janome 6500 has a bobbin case held in by magnet on the underside and it will dislodge and move if there is a jam up. This then prevents it from forming stitches correctly. You need to lift out the bobbin case and put it back into position. With mine, when it has moved, the needle then strikes part of the case when it comes down. This often results in a burr in the plastic which then causes the thread to catch again even when the case is back in correct position.
There should be two marks, one on the case and one on the outside to align it to.
9k=
this is my bobbin case, and the cut away part on lower part of the image is the bit that goes into the machine away from you.
Feb 07, 2014 | Janome DC3050 Computerized Sewing Machine
My janome DC 3050 keeps showing bl when i make a button hole
BL stands for buttonhole lever,, it's to the left side of the needle bar,,just pull it down when you want to make buttonholes & when your finished making buttonholes,, just gently push it back up
Sep 20, 2011 | Janome DC3050 Computerized Sewing Machine
My janome 3050 keeps showing bl when i make button hole
Free to view or download from Janome Manual Janome DC Model#3050 http://www.content/Janome.com/ Simply type into browser. Saw your question and hope this is helpful. Jimmy
Janome 3050 shows bl when i make button hole
bl stands for buttonhole lever--the buttonhole lever is to the left of the needle bar---pull the buttonhole lever down as far as it will go & when your done just push it back up
Bobbing thread not picking
Make sure you have threaded the bobbin thread correctly. Also your top thread must be correctly threaded in order to pick up the bobbin thread.
Please let me know if I can help any further.
Best wishes,
Graemevm
May 01, 2009 | Janome 6019QC Mechanical Sewing Machine
Machine will not pick up bobbin thread
Apr 20, 2009 | Janome Sewing Machines
Tension Problems with Janome DC3050
If your machine is binding. It sounds like you have a threading problem. Check your manual and rethread the machine. The A is for Automatic tension I would not change that. I would also notify your dealer and see if you have thread under the bobbin case. All sewing machines should be serviced each year.
Dec 13, 2007 | Sewing Machines
Janome DC3050 Computerized Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
