Question about Panasonic Televison & Video
Vertical lines TC-21GX10PS - Panasonic Televison & Video
My panasonic plasma started showing vertical lines
Look at the buffer board or the Y sustain board on a plasma having picture aberrations.
Sep 16, 2016 | Panasonic Viera 50" Class 1080p Full HD 3D...
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Service menu of crt tv panasonic model tc-21GX10PS
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given.Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin.Be very careful.Note how to "EXIT" the service mode; after entering and adjusting data.This is very important.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Mar 02, 2015 | Panasonic Televison & Video
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
Circuit diagram TC-29P20B
Vertical scan output section circuit fault. Horizontal line problem. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 29, 2014 | Panasonic TC-29P22R 29" TV
Circuit diagram TC29P20B
This is vertical problem
check vertical ic volt & vertical yoke coil
How do I get rid of green line?
your problem is a faulty T CON BOARD.
Part number TCON BOARD 6870C-0060F
hope 2 help
www.bostonrecycling.net
Jun 30, 2012 | Panasonic TC-32LX70 Television
Thin red vertical line on plasma tv screen, can be fixed at home? Panasonic tc-p42c1.
vertical line on screen 80% up pdp panel problem
if you need replaced you can try call bestbuy in home service....
Dec 04, 2009 | Televison & Video
Black screen with colored vertical lines
YPU HAVE A BAD PANEL. THE COST OF REPAIR WILL PROBABLY EXCEED THE VALUE OF THE SET.
Mar 20, 2009 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Televison & Video Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
