Question about Frigidaire Washing Machines
Frigidaire affinity front load washer error code e10
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
MakeupWizard
  • 39 Answers
SOURCE: What does error code E59 means on a Frigidaire
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Posted on Apr 22, 2010
  • 1382 Answers
SOURCE: What does the code E10 mean? The washer flashes
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
Posted on Jun 28, 2010
SOURCE: Frigidaire Affinity Front load washer,
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Posted on Aug 30, 2010
Error E10 keeps popping up and washer stops 2 or 3 times during cycle and have to reset it
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Here could find additioan sample guide details: fixed-frigidaire-affinity-washer-gives-e10-error
Hope helps.
May 03, 2011 | Frigidaire ATF6000ES Front Load Washer
E10 on my Frigidaire Affinity Front Load Washer
just go to fridge website support center and see what the code is or google Frigidaire code 10
Jan 22, 2011 | Frigidaire Washing Machines
What does the code E10 mean? The washer flashes that code and won't spin.This is and Affinity front load washer.
Thank you !!
Jun 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error code E10 what is it
Thank you !!
May 31, 2010 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire Affinity Model atf6000fs0 Washer presents two error codes at beginning of each cycle - EF0 after about one minute and the E10 after a few minutes - cycle stops there. Nothing else happens....
My Affinity (M - ATF6000FS0) fails to an E-20 code. The troubleshooting guide helped; however, the code continues to come in. The drain line is clear to the pump, but the pump sounds like it is failing. Guidance, insight, feedback....please!
Feb 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000Es1 washer- Keep getting an alarm and an E10 code and have to restart the washer each time the code comes up.
Oct 18, 2009 | Frigidaire Affinity ATF6000F Front Load...
I am experiencing an error code during my wash cycle of E10... I have a frigidare affinity series washer.
Clean the cold water filter on the back, then try again. This should work. Mine was doing the same thing and the repairman had no idea what it meant.
Jan 08, 2009 | Frigidaire Affinity ATF7000ES Front Load...
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
E10 code
I believe E10 means there is a draining problem. Check your drain hose and see if that is where it should be and not clogged. If that is okay, most likely your pump is clogged.
Aug 28, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
21 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
