Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Canon IR2545 showing the error code E000000 - Canon imageRUNNER 3300 All-In-One Laser Printer
  • 57 Answers
SOURCE: Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Posted on Sep 03, 2009
57 varieties
  • 1653 Answers
SOURCE: canon image runner error code E000000-0000
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
Posted on Oct 13, 2009
spinal
  • 287 Answers
SOURCE: error code E000000-0001
Hello nelco9,I can help you clear the code easy enough. But there is a strong probability the code will come back almost immedietly.Copiers use high heat and pressure to bond the toner to the paper.It is of course critical to accurately monitor this high temp as to insure against fire.The code E0000000-001 means that for any number of reasons the copier did not or could not reliably monitor this temp.Now, something as simple as a momentary variation in the power to the plug the device is plugged into can cause this code as the plug voltage and/or frequency is sufficient to interfere with the copier's ability to track the temp, so lets hope for the best.Trust me there are so many fail safes involved in this process that the copier will properly shut down if the problem is serious.Ok,locate the'ADDITIONAL FUNCTIONS" button on the op panel.It is just to the right of the 9 key pad.Press it, let go, then the numbers 2&8 simaltaneously,let go, then ADDITIONAL FUNCTIONS again.You will see a new screen.Press "copier". Tabs appear at the top.Press the "function" button.New screen again.Press "clear".New screen.Press "ERR" .Press "OK" in the lower right corner.Now if you TRULY know where the main power switch is (right rear of copier about halfway down) then power the copier off.If in doubt simply unplug the copier.When you turn it back on the copier will attemt to start up as normal.If it does then congrats !!.If it fails you will need a new fusing unit which can run as high as $800. I truly hope I have helped you.Take care.
Posted on May 02, 2010
canontech
  • 1219 Answers
SOURCE: canon error code E000000-0000
Some of possiblle causes:
The heater has an open circuit.
The thermal fuse has blown.
The High-voltage PCB has a fault.
The DCNT PCB has a fault.
FIRST:
under service mode * 2 8 * :
COPIER-FUNCTION-CLEAR-ERR-OK
Turn off and on.
if that doesnt help replace fixing film assy.
Posted on Jun 30, 2010
SOURCE: I HAVE A CANON IR
my xerox problem E000064-0000
Posted on Mar 15, 2011
What do I do if the machine stopped working showing the error code E000000
That error code means your Canon failed to warmup properly. Could be a bad Fixing assembly. Sometimes it is possible to just reset the code and then you may continue to use the machine. Based on the error code you provided, I assume you have a Canon but you need to post the model number to receive more detailed advice.
Sep 17, 2014 | Office Equipment & Supplies
Im getting error e000000-0000
ok the Error code is to do with your fixing unit, you need to go into service and clear the error then reset machine should work again.
do a search for clearing fixing unit error code on your canon copier, wont be to hard to find
canon copier tech
Mar 30, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Imagerunner 2220i Error Code E000000-0000
canon printer ir 2200 error E000000-0000 my help
Feb 05, 2009 | Canon imageRUNNER C3220 Color Copier
Canon Imagerunner 3570 error code
if u r still having this problem with the imagerunner 3570 u can try this:
press * 2&8 together then * again
go to function
then to clear
select eroor then ok that should take care of ur issue
Jun 08, 2008 | Canon ImageRUNNER 3570 Copier/Printer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
91 people viewed this question
old marine
old marine
