Question about Sunbeam Vacuums
How to use sunbeam vegas slow cooker - Sunbeam Vacuums
WHERE CAN I GET USER MANUAL FOR RUSSELL HOBS SLOW COOKER 18224
this site says it has it but i am having an issue when clicking the instruction booklet link im not getting anything to come up http://www.russellhobbs.co.uk/russell-hobbs-products/cooking-baking/slow-cookers/6-5litre-digital-slow-cooker-18224.html but you can also goto there customer service on this other link and they would be more then happy to attend to your needs with any manuals or instruction booklets http://www.russellhobbs.co.uk/contact_us.html if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Feb 26, 2011 | Vacuums
I need a lid (cover) replacement for my rival slow cooker model scv551. The plastic lifting piece has cracked.
I need a replacement cover for my Rival Slow Cooker size 3.5 quart Model 3730. Where can I get it?
Feb 06, 2011 | Vacuums
My slow cooker doesn't heat enough. My recipes say to cook on low... but after 10 hours the vegetables are not cooked. Is there a problem with this model? Thanks
Most slow cookers have several settings ... maybe yours is one ... I suggest you select a higher setting.
Thanks for visiting today.
Jan 28, 2011 | Vacuums
Bravetti Slow Cooker won"t heat
Well if your o.k with soldering...or know a handyman...it more than likely IS repairable. The manufacture puts in a thermal fuse that blows when the temparature gets to high. Radi0 shack stocks them...and might know of a local person to test / fix it. http://www.google.com/products?rls=HPIB,HPIB:2010-05,HPIB:en&q=thermal+fuse&um=1&ie=UTF-8&sa=N&hl=en&tab=wf Here is what it looks like. AND you need to get the RIGHT tempature rated replacement. Hopefully a 10-20 dollar fix will save you 50-120 for a new one. Maybe you will get lucky and the fuse clips in like a vehicle fuse. http://www.radioshack.com/search/index.jsp?kwCatId=&kw=thermal%20fuse&origkw=thermal%20fuse&sr=1 Good luck Richard
Nov 14, 2010 | Vacuums
I have an Everstar slow cooker. i need to replace the ceramic pot. it is crAcked.
Hi This section is to do with Vacuum Cleaners. Please relist under the correct section. Many Thanks
Oct 27, 2010 | Vacuums
I purchased a Sears Counter Craft Crock Watcher crock pot at an Estate Sale, but there is no instruction booklet. It has low, high, and auto shift on the dial. Can you help provide some instructions for...
From a couple of different slow cooker manuals - most I looked at are the same:
When in the AUTO setting, the slow cooker will begin cooking on HIGH and then will shift to LOW after approximately 2 hours of cooking time. AUTO setting does not turn off the unit. Other favorite recipes may be adapted to the slow cooker. All times listed in the following chart are approximate and should serve only as cooking guidelines.
Regular Cooking Slow Cooker Cooking Times
1 (Low) 2 (High) AUTO
30 minutes 6-8 hrs. 3-4 hrs. 5-7 hrs.
35-60 minutes 8-10 hrs. 5-6 hrs. 6-8 hrs.
1-3 hours 10-12 hrs. 7-8 hrs. 8-10 hrs.
Sep 16, 2010 | Vacuums
Have lost manual for my sunbeam dehydrator model AR72716 07-03 cannot locate one any where
Sunbeam only have 2 listed:
  • DT100E Healthy Food Dehydrator link to manual: http://www.sunbeam.com.au/PDFDownloadHandler.ashx?id=11092
  • DT5600 Food dehydrator link to manual : http://www.sunbeam.com.au/PDFDownloadHandler.ashx?id=11096
Does your dryer go by another name such as Excalibur?
Sep 06, 2010 | Sunbeam Vacuums
Vacuums Logo
16 people viewed this question
Top Sunbeam Vacuums Experts
Are you a Sunbeam Vacuum Expert? Answer questions, earn points and help others
