Question about NetGear Computers & Internet
Can i block the wireless intruders while they know the password
  • NetGear Master
  • 2,219 Answers
Change the password!
Posted on Mar 08, 2015
How can i block intruder?
If the Wireless device isn't secured, Secure it. Set up a SSID and Security Key(password). If it is secured, change the Security Key(password), Use the Linksys Setup Manual found here: http://support.linksys.com/en-us/support/routers/WRT120N Always Secure your Wireless. If unsecure your signal, at best, COULD be use by anyone to connect to the web using your resources and slowing down your activity. At worst, use your signal for nefarious purposes causing you a great deal of Pain and Heartache, and MAYBE the FBI knocking at your door.
Mar 20, 2013 | Linksys WRT120N Router
My router is password enable before but no its not,how can i make it passsword enable again?i know my password
Here are some basic steps in setting up your Linksys router
Hope it helps!
Please follow the below instructions to protect your device:
  1. Connect your computer to the router using a network cable, or you can connect to the router through a wireless connection. Note that your wireless card in your computer must be enabled.
  2. Open your Web browser. Enter: http://192.168.1.1 in the address field. This is an internal IP address to access your router. Press the Enter Key.
  3. When the password request appears leave the user name field blank. By default, the password is admin.
  4. After logging in, you are not required to change the default administrative password. However, it's fully recommended that you change the default password by clicking on the Administration tab and Management. Enter a new password in the Password field and again in the Re-enter field to confirm.
  5. I recommend setting the Remote Management item as Disable. It will be another layer of security for your router. With this configuration you can only access your router for programming using a standard Ethernet network cabling.
  6. To save the new password, click Save Settings at the bottom of the page.
  7. To avoid intruders accessing your wireless connection we'll start to work with the Wireless tab.
  8. In the Basic Wireless Settings enter a name for your wireless network connection in the Wireless Network Name (SSID). Set the Wireless Broadcast to Disable.
    When wireless clients survey the local area for wireless networks to associate with, they will detect the SSID broadcast by the Router if the Broadcast is enabled. Do not broadcast the Router SSID. It must be Disabled.
    Note that your SSID should be set following similar rules for setting a password, e.g. at least 8 characters, a combination of letters, numbers and non consecutive characters.
    Disabling the SSID broadcast is not a strong security setting, but it can help prevent intruders from sharing your WLAN. Remember to save your settings.
Jul 15, 2011 | Linksys Wireless-G WRT54G Router
I want to block facebook on my att 2wire router i dont know how to access the router from my main pc to block facebook and my space
192.168.1.254 or 172.16.0.1 are the ip addreses you have to type into your browser while your computer is connected (wired prefered) to your router. Once the login comes up you need to type in username and password which are...2wire (username) with blank password OR Wireless (password) with blank username... You can make your changes from there... if you have any further questions let me know....
LIke this if it helped you !!!!! Please!
May 16, 2011 | 2wire (2701HG-B) Wireless Router
I just installed a wirelss linksys wrt54gs v4 router in the bk bedroom, with my office computer equipment,,my wife has a wireless hp pavilion 6000, that she would like to use in the living room,40 ft away...
Hello
Try updating the firmware on the router.You need to log into the router using 192.168.1.0
Username =admin
password = admin or the word password.
Once in the routers home page check for updates and download and install.Also be sure any firewalls are not blocking the signal.
While your in the router set up a personal wep key for your wireless security.
There is a possibility your lossing signal to outside intruder.
Apr 21, 2011 | Linksys Wireless-G WRT54GS Router...
Our router is visible for others and everyone has free access! how to block this router for others?(network is unprotected now without any password or whatever). Thanks in advance. E
  • Please follow the below instructions to protect your device:
  • Connect your computer to the router using a network cable, or you can connect to the router through a wireless connection. Note that your wireless card in your computer must be enabled.
  • Open your Web browser. Enter: http://192.168.1.1 in the address field. This is an internal IP address to access your router. Press the Enter Key.
  • When the password request appears leave the user name field blank. By default, the password is admin.
  • After logging in, you are not required to change the default administrative password. However, it's fully recommended that you change the default password by clicking on the Administration tab and Management. Enter a new password in the Password field and again in the Re-enter field to confirm.
  • I recommend setting the Remote Management item as Disable. It will be another layer of security for your router. With this configuration you can only access your router for programming using a standard Ethernet network cabling.
  • To save the new password, click Save Settings at the bottom of the page.
  • To avoid intruders accessing your wireless connection we'll start to work with the Wireless tab.
  • In the Basic Wireless Settings enter a name for your wireless network connection in the Wireless Network Name (SSID). Set the Wireless Broadcast to Disable.
  • When wireless clients survey the local area for wireless networks to associate with, they will detect the SSID broadcast by the Router if the Broadcast is enabled. Do not broadcast the Router SSID. It must be Disabled.
  • Note that your SSID should be set following similar rules for setting a password, e.g. at least 8 characters, a combination of letters, numbers and non consecutive characters.
  • Disabling the SSID broadcast is not a strong security setting, but it can help prevent intruders from sharing your WLAN. Remember to save your settings.
  • Enable network authentication and encryption. Listed in order strongest to weakest:
WPA2-PSK (data encryption TKIP or AES)
WPA-PSK (data encryption TKIP or AES)
WEP (256 Bit) - Weak, but better than no encryption
WEP (128 Bit) - Weaker, but better than no encryption
WEP (64 Bit) - Weakest, but better than no encryption
plz do rate the solution if got help
Nov 23, 2010 | Linksys Wireless-G Broadband Router
How do i install a password in my wireless rauter, to prevent intruders access? Linksys/Cisco 192.168.0.1
Hi Friend,
In order to resolve the issue please follow the steps:
1.Please connect the router with a computer
2.Type 192.168.1.1 in the address bar of the Web browser(e.g-Internet Explorer) and hit enter
3.Enter the Username and the Password (defualt password is admin and leave the user name blank)
4.Now on the Router setup page click Wireless tab and fill the sections as mentioned:
Wireless Network Mode-Mixed
Wireless Network Name-As per your choice
Wireless Channel-6-2.437GHZ
Wireless SSID- Enabled and click Save Settings
5.Now click Wireless Security tab.
6.Select the Security mode as WEP and fill the sections as mentioned
Default Transmit key- select 1
WEP Encrypion-64 bits 10hex digits
Key1-Enter 10 digit or 10 letter password(e.g-your telephone number) and click Save settings.
Now turn the router for 30 seconds and after that turn it on.
Try to connect your wireless devices, it will ask for a password which will determine that your network is secured from intruders.
I hope this will resolve the issue.
Regards
Chiranjeet
Jun 02, 2010 | Linksys Computers & Internet
I want to set up a password for my internet access so neighbours/intruders can't hack me stupid,please help
go into your wireless then security settings and select WEP and type a phrase and click generate it will give you a key.... that key is your password for your wireless network. it will ask them for the key when they try to connect to your wireless router... so if they dont know the key thay cant get in and use it...
Hope this helped...
Jul 20, 2009 | D-Link AirPlus® G DI-524 Wireless Router
Blocking sites
change the password
Apr 07, 2009 | Computers & Internet
How do I enable wpa encryption? I have an
To set up the correct security protocols for your router:
1 Click Control Panel > Device Security.
2 In the Login User ID field, enter your User ID. Create an ID that contains multiple casesensitive
characters as well as numbers. It cannot be longer than 64 bytes.
3 In the Login Password field, enter your Login Password. Create a password that
contains multiple case-sensitive characters as well as numbers and symbols like “_ + )”.
4 Re-enter your Password.
5 Click Apply.
6 Once the settings have been accepted, click Restart and log back into the
Configuration Utility using your new User ID and Password.
7 Select Wireless > Basic.
8 Change the SSID to a user-friendly name and click Apply.
9 Navigate to Wireless > Security.
10 Select WPA-PSK from the ESS Authentication options.
11 Select TKIP from Encryption Status options.
12 Click Apply and then click Restart. Your wireless security configuration is now
complete.
Mar 26, 2009 | Arris WR850G Router (DHWR850G)
How to protect my belkin 54g wireless connection from intruders. Please help me with that
There is no sure way to stop intruders - if they want to get in they can and will.
However in saying that you can certainly be smarter than the average jo driving around an estate looking for open wireless routers.
First thing first, always change the default password for the router (admin, password). If you can, change the username also (from admin to something else).
Secondly I would recommend that you enable some kind of WPA (or WEP) protection. This basically means that anyone attempting to connect to your wireless will require a "password" to connect to you. The more bits the password has the longer the password is and usally the harder it is to crack (via a brute force attack).
Thirdly - Hide your SSID. All routers by default show to the world they exist. If someone doesnt see it broadcasting generally they wont know its there.
Forthly. I would recommend setting up access lists. On every network card (be it wired or wireless) has a unique identifier called a MAC address. An access list restricts which MAC addresses can physically connect to your router. To find out your mac address click Start - Run. Type CMD. Type IPCONFIG /ALL
Fifthly - This may require a bit more fiddling around between both the router and PC's but may be worth it in the long run. Most routers broadcast whats called DHCP. This is what gives you an internal IP address. If your router allows you setup the DHCP settings to something incorrect EG: Different Subnet mask, DNS settings, Default Gateway. Then setup your home PC's manually to the correct settings. This way if someone does end up cracking your router it will throw another curveball at them as they will not be able to surf the net, view your shared files, without more fiddling.
As far as PC based security goes, I would suggest that you check any shared files or folders you may have and disable, setup how many people can use it at once, permissions etc for them. Best way to check would be Click Start - Run. Type \\127.1.1.0 <- This will connect to your pc via the network.
Apr 21, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
