Question about Schwinn 430 Elliptical Trainer
Need manual for vmax cross trainer
I can't get the display to work or increase resistance. Any ideas?
Need a repair to crosstrainer
Sounds like the pulley (bearing) in the back is loose or broken
Apr 27, 2014 | Tunturi C80 Elliptical Cross Trainer
576i resistance not increasing precor
If the display stays at 1, then the UP button may be at fault, in which case you would need a new keypad.
Jan 02, 2014 | Precor EFX 546i Elliptical Version 4
Resistance
This could be caused by either a bad lower electronic board or the brake/generator. I am attaching a link to the service manual for you for further reference. http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/Service%20Manual,%20C546i%20Self%20Powered%20EFX.pdf
Jun 27, 2013 | Precor EFX 546i Elliptical Version 4
Resistance does not increase
please read the instruction and fix it. God bless you
Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.Test with the magnet from a refrigerator, If the magnet attract and repulse, is o.k If not replace the magnet.1_21_2013_5_29_53_pm.gif
Jan 20, 2013 | Schwinn 420 Elliptical Trainer
My Kinetic trainer increases resistance when I increase speed. How can I maximize resistance at low cadence of say 60 rpm?
You can't with this type of trainer. You have to have a trainer where you can manually adjust the resistance. The closest you can do is shift your gearing.
Apr 04, 2011 | NRS Kinetic Road Machine Trainer
How to increase resistance on Blackburn Tech Fluid Trainer? I know it is supposed to increase with rpm's, but I am not a strong rider and I just rode 90 minutes in my biggest gear with only moderate...
Fluid trainers work by providing resistance that increases as your effort increases, much like riding on the road. There is not a switch or lever to increase the resistance with this specific trainer. So in short you have to put in a bigger effort to get more resistance. Putting in more effort and increasing your Cadence (rpm's) will provide a harder resistance and will decrease your duration attainable. This is OK. One of the benefits of using a trainer is that you can get more accomplished in less time.
Mar 25, 2011 | Cycling
Instruction manual for olympus cross trainer
I cannot get the timer to work on the olympus sport ascent cross trainer.
Jun 28, 2009 | Exercise & Fitness
E1 Error Message on Reebok Cross Trainer
i too have this problem am under the impression there is a problem with the resistance but am waiting on areply from reebok technical support
Mar 27, 2009 | Reebok Exercise & Fitness
Schwinn 430 Elliptical Trainer Logo
Top Schwinn Exercise & Fitness Experts
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Bill Boyd
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
