Question about Avaya 1608 IP Phone
Reset password after changing the extension is not accepting the password it show password error .
My Nortel phone NT8B27JAAE6 has locked me out of the voicemail. Can you tell me how to reset it???? Thanks Agatha
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you the extension of the line you are using.
May 09, 2011 | NorStar T7316E Corded Phone
My MBOX is locked on my T7316E Nortel phone. Also, trying to retrieve messages from home I somehow changed the password and I don't know what it is.
Feature 985 will show you your mailbox extension
Apr 25, 2011 | Nortel T7316E 2-Line Corded Phone
My nortel n441 says locked mailbox this happened after trying to change password can you help me
Feature 985 will show you the extension of the phone you are using.
Mar 17, 2011 | Nortel T7316E 2-Line Corded Phone
I'm locked out of the voicemail feature and I can't find a way of activating a new password to pick up messages. It's a Nortel T7208 system. Has anyone any ideas?
Feb 18, 2011 | Platinum Norstar T7208 Telephone
T7316E Voicemail Password Issues
Feature 983
password is: 1020000 (if you use 3 difit extensions)
OR
120000 (if you have 2 digit extensions)
Jul 09, 2009 | Nortel T7316E 2-Line Corded Phone
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 15, 2009 | NorStar Lands Phones
Mailbox problem
The following instructions will only work if your System Administrator password is set to the default. Usually the default is 0000.
Oct 21, 2008 | Nortel T7316E 2-Line Corded Phone
My General Delivery password is invalid.
Normal 0 To Log Into System Administration:
then
Normal 0 2. Select the softkey under "MBOX"
Aug 26, 2008 | NorStar M7310 Corded Phone
Initialising Mailbox
To Change the "Recorded" Name for the Company Directory:
1. Have the Voicemail User log into their mailbox, after putting in their password, press the button under "Admin" (or press the number 8 key., and then press the number 1 key.
2. You will hear the old recorded name and then the system will "beep", prompting you to record a new name (name only here, not greeting..
3. Press "Ok" in the window when you are done recording and then "Ok" again to accept the recording
Apr 23, 2008 | NorStar M7310 Corded Phone
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Avaya 1608 IP Phone Logo
55 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
