Question about Disney Video Game Consoles & Games
Tron Evolution Installation saying Cyclic Redundancy Check Failed
When I received Tron:Evolution , I put it directly in my DVD:ROM Drive but when I installed it , It said a CRC error has occured and the installation closes automatically. Is there a way to fix this , PLEASE ?
bbtoast
  • 319 Answers
SOURCE: cyclic redundancy check
These errors can occur if you install Pro Tools before installing the WaveDriver, or have an incorrect driver installation.
Please go to this link for complete instructions, or I can send them to you!
http://www.digidesign.com/index.cfm?navid=54&langid=1&itemid=14257
Posted on Jan 02, 2008
  • 70 Answers
SOURCE: The Sims Unleashed/Superstar/Makin' Magic Installation Problem
This error means that the data is corrupt, if you get it from Valve or via some other download try to download it again, if you have it on a cd/dvd than give it a try with this.
The worst case scenario is that your system memory is faulty, you can try to figure that out the easiest way by downloading some l linux live and choose memtest utility from it's boot menu and let it run through your memory a few times.
SLAX is a very small one, only 200Mb, but it's perfect for the job, just set boot from cd first in your bios and start the computer wit this cd.
You'll see something like there's a problem with your memory:
Regards
Imre
Posted on Nov 28, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: A problem with installing lego creator harry potter.
Try cleaning the disc first. There may be dirt or fingerprints interfering with reading it. The CRC error means the data is not being read correctly. If the error continues and this is a game you recently purchased, I would recommend returning it to the store and exchanging it as it's probably a defective disc. If you are trying to install a copy you downloaded you should try downloading again as there is some error in the data.
Posted on Mar 12, 2009
SOURCE: Does Emperor RotMK work with Windows 7?
I have Windows 7 32bit and was able to successfully install Emperor ROTMK. I used to get that error with an old disk I had. it was because my disk was damaged.
Posted on Mar 13, 2010
Data error cyclic redundancy
Hi
There are several situations that might have caused a damaged to the driver.
DATA ERROR CYCLIC REDUNDANCY might have been caused by a Virus attack. And in those cases, you will provably end up buying a new hard drive.
How would I know that? Well, just check your memory and remember if you had been doing some Internet search/chat/downloading some stuff/visiting unknown sites, etc., prior to the damage.
It ussually happens when you are using Chat programs, in which you may have received a file or a link to visit to
(most likely the virus made an unrecoverable damage on the main section of the drive, the MBR - Master Boot Record)
Feb 07, 2014 | Western Digital My Passport Essential...
Tip
The NASTY "CRC" Error ......Tackle IT
What does CRC(Cyclic Redundancy Check “error”) mean?
There are plenty of technical resources on the Web that discuss cyclic redundancy checks (CRCs). Most times you won't need to worry about this technobabble. That is, until one it day it suddenly appears and you think - what the hell does that mean? In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear.
The most common time you will see the cyclic redundancy check error message is when trying to read data from a damaged CD or DVD. Just before it appears, your CD/DVD drive will probably grind and whirl away - your PC may also become a little slugglish.
Less frequent causes are the result of system crashes, and buggy software (hello Microsoft), incomplete downloads (often identified by the misleading message 'This is not a valid Windows file', 'This is not a valid win32 application' or 'Corrupt Zip file'). If this problem happens frequently with downloads, try using a download manager.
For CDs and DVDs, the problem is a little different. Normally, when CD/DVD drives get a CRC message from a disc, they try to read the disc again - hence the grinding sound. After several failed attempts, they give up and display the redundancy check error. The problem can be hardware (loose cables, failing drive), software or damaged media. In most cases checking and cleaning the disc is the easiest way to overcome the problem. If different clean discs produce the same error, it is likely to be a hardware issue (check the discs in another drive). Another common cause of these errors is poorly burnt CDs and DVDs - especially those that had numerous or severe buffer underuns. USB burners suffer from this problem when the burn speed is too high (generally above 4X-8X)
If the discs are damaged, you'll probably need a recovery tool to get back your data. CDCheck 3 will work for CDs and DVDs. First it will check the media, and then you have the option to recover the files. It's free for personal use and has saved many people heartache when it comes to recovering lost digital images and videos from damaged CDs.
on Dec 22, 2009 | Computers & Internet
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Cyclic redundancy error
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
500 MB data error(cyclic redundancy check) external hard drive is not accessible
1. this ( cyclic redundancy check) is the computers way of saying " i don't recognize the data check-sum.
2. This issue could be due to the data controller on the USB drive being defective.
3. try purchasing a new case with a new controller board.
4. Check to see if your 1TB USB drive is compatible with your pc.
Jun 13, 2011 | Toshiba 1TB Canvio for Mac USB 2.0...
Hello. I am installing XP Service Pack 2 on my Desktop and during extraction the Cyclic Redundancy Check problem occurs. Could this be a hardware problem? AQny help will be appreciated. Thanks
The computer is having problem extracting the files from the service pack 2. The file may be corrupted if you are installing it from a CD. This is unlikely a hardware problem.
I suggest you install SP3, this is the latest service pack and it includes SP2.
Jan 24, 2011 | Computers & Internet
We have been given the PC game V8 Challenge, but am unable to install the game. It installs to 88% then says: "Data Error (cyclic redundancy check)". Please can you advise as to how we get thte...
a Data Error (cyclic redundancy check), is usually a problem with the CD, is the CD dirty? you might try cleaning it, (you can pick up a CD cleaning kit at Walmart for $5). Or you might have a problem with your CD drive
Jan 04, 2011 | Computers & Internet
I downloaded some videos to my hard drive. When I try to burn them on or erase them from my DVD, I get this error: "Error 0x80070017: Data error (cyclic redundancy check)". What should I do? Note: ...
Cyclic redundancy is one of the data checking algorithms and it is getting a non-recoverable error for some reason.
I suspect the software you are using to burn the DVD may be corrupt or incompatible with your Vista operating system.
It ALSO might be that the video is COPYRIGHTED and you are being blocked from copying it to a removable medium. There is no solution for that situation.
Feb 09, 2010 | Creative Labs (7300000000268) 20 GB Hard...
check this site out
http://www.softwarepatch.com/tips/cyclic-redundancy.html
Jul 09, 2009 | Computers & Internet
Video Game Consoles & Games Logo
35 people viewed this question
Top Disney Video Game Consoles & Games Experts
James Wishart
Dan Shibata
Dan Shibata
Are you a Disney Video Game Console and Game Expert? Answer questions, earn points and help others
