Question about HP Color LaserJet 9500HDN Printer
How to resit 50.6 fuser error 9500 - HP Color LaserJet 9500HDN Printer
4 Suggested Answers
  • 16 Answers
SOURCE: hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Look at fuser rollers and make sure the new one doesnt have spacing to far in between rollers. Also on front side of fuser there is a big connector that meshes with one inside machine. The fuser connector assy RG5-5925-000CN could be broken as well
Posted on Mar 02, 2010
seeker5211
  • 1089 Answers
SOURCE: hp 9500 hdn - error message 57.70. Can I relace
No!
The 57.7 error says that the fuser fan could be bad.
If you take the back cover off the printer and look to the right, you will see two fans, one above the other.
The bottom fan is the one you want. It is probably clogged with dirt or else the dirt got inside the fan and is preventing it from spinning. Replace it
Posted on Apr 04, 2011
vladmototole
  • 226 Answers
SOURCE: 50.a fuser error
Change the fuse!!!
Posted on May 21, 2012
Getting a 50.6 FUSER ERROR on a HP color Laserjet 9500 printer. I bought the image fuser kit and replaced it. Still getting the error. Suggestions?
check the connector that the fuser connects to for damage. If the plug is intact you will probably need to replace the power supply (Low Voltage PS) C8546-69003 is the part number
on a unit of this vintage the part won't be cheap. A quick search on the net shows it from $350 - $600
Good luck
Dec 04, 2015 | HP LaserJet 9500n Printer
I have hp 9500 but it show me 50.6 fuser erro I change the fuser it still the same
Please read through these troubleshooting steps and suggested repairs: http://www.laserquipt.com/support/idx/46/292/article/-50x-Errors.html
Apr 17, 2015 | HP Office Equipment & Supplies
Konica 7020 trouble code 36-1
dear need help to resite l detect value auto adjustment developer konica 7020
Feb 26, 2013 | Office Equipment & Supplies
50.4 fuser error 4015 laserjet
Faulty fuser..Remove back tray, take out & resit fuser assembly properly, observe that fuser lock are clicked or not,if you feel seated properly, switch on and shoot print command.. If its printing well then you are in in safe side, other wise replace fuser assembly just little bit expensive...
Feb 02, 2012 | HP Office Equipment & Supplies
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
Hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Jan 21, 2009 | HP Color LaserJet 9500HDN Printer
Canon MF8170C Error E000
This is due to the Fuser Unit, could be fuser sitting out of line or connectors, if not then it could be the fuser unit it self such as thermistor. I would remove it and resit it and then see what happens, if not replace Fuser,
As worse it could be down to the lower voltage power supply but as yet i have never had that problem!
hope this helps
Oct 21, 2008 | Office Equipment & Supplies
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
HP Color LaserJet 9500HDN Printer Logo
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
