Question about Kitchen Appliances - Others
Honeywell vr8440p2088 gas valve.. Q the on/off switch is broken and overturned since it will turn 360 how do i get the correct position
2 Suggested Answers
  • 744 Answers
SOURCE: I have a HEIL furnance with a bad Honeywell gas
Have your furnace model and any part numbers handy.
Then visit or call this supplier:
http://www.apwagner.com/
Posted on Jan 02, 2010
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 07, 2011 | Honeywell Water Heaters
GE JGP 945 continues to spark. Removed all igniters but continues to click. Bad Spark Module?
no,its a bad switch on one of the gas valves,they are piggybacked on the gas valve and are supposed to turn on and off as the valve is turned on and off,on has broken and is on all the time even with that valve in the off position,carefully remove each switch from the circuit till it no longer sparks with all the valves in the off position
Mar 30, 2011 | GE Profile JGP636 Gas Cooktop
Hi, I want to replace my Honeywell gas valve ( Model VR8440P2088), but I don't know with model is compatible to replace it. Can I replace it with different model ? Please help. Thanks
It is very important that you replace your gas appliance with the same model gas valve. Gas valves function diferently from appliance to appliance. Some open slow, some are two stage, ect. Your safety is very important!!!! To save a few dollars on a gas valve not for your application is dangerous.
Mar 15, 2010 | Honeywell Heating & Cooling
Honeywell Gas Valve inoperative
Gas valve is probably dead. With the numbers directly off the valve, you may find a place to sell you one. Don't try and repair the valve. Will probably cost as much to by a new one.
Good Luck
Feb 21, 2009 | Honeywell Electrical Supplies
I have a dayton furnace with a honeywell vr8440p-2088 gas control. The ignition works fine but the problem is I am getting no gas it seems to light the pilot. I checked the orifices at the end of the pilot...
I had the same problem with the same honeywell vr8440p2088 gas controler.  I found out the nob to turn on the pilot was broken.  If you can pull the knob off it is broken.  The knob has two small teeth on it to keep the pilot and gas open.  good look finding a replacment knob as the part is not made anymore.  But there is a relacement part for it.  it just costs about 250.00.
Apr 18, 2008 | Honeywell Heating & Cooling
WIRING DIAGRAM LOST FOR NON-PROGRAMMABLE CT87
Red is power return to turn on heat
White is common power to both heat and cold
Blue is power return to turn on AC
You can get specific guidance on wiring at the Honeywell Website.
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0274.pdf
Apr 12, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Kitchen Appliances - Others Logo
137 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
