Question about Bachmann Ho Gp35 W/dcc, Wm 3579 Bac60708
Loud gear noise - Bachmann Ho Gp35 W/dcc, Wm 3579 Bac60708
    New Friend:
  • 161 Answers
Lubricate your gears
Posted on Oct 15, 2014
How do I silence or quieten the reverse noise ?
reverse gear is what is called a spur cut gear and because of that it generally is noisier that the other gears
it runs on it's own idler shaft and there most probably will be a bearing problem that is allowing the mesh of the gears to alter and that will make the reverse noise louder than normal
so it is either a bearing on the way out or because of the way the gears are cut , a tooth could be chipped or partially broken off (slashing reverse inadvertently when selecting from 5th back to 4th)
the fix will be a box overhaul of the bearing or gears
Sep 05, 2015 | Cars & Trucks
1995 GMC SONOMA makes a loud sqeaking noise when i take off in the first to third gear, after third gear it stops, but when i get to a stop sighn it starts all back over, loud noise.
This type of noise is likely to be a universal joint that is worn out in the drive line. have a shop put it on a lift and inspect the joints.
Jun 06, 2012 | 1995 GMC Sonoma
On my Saturn 2003 Ion, the starter makes an extremely loud noise upon turning key in the ignition. The problem is recent and literally sounds like something is going to disengage or break. Otherwise, car...
if noise is only when starting, consider replacing the starter. the mounting bolts could have some loose, or the clutch which disengages the starter gear is not retracting the gear. either situation could cause a loud noise of the starter gear clattering with the ring gear.
Jun 27, 2011 | Saturn Ion Cars & Trucks
When driving my 2000 Olds Bravada, it has a loud roar noise that sounds like when a semi truck is taking off before the gears are shifted. Transmission shifts easily into gears, just this loud roar noise...
If there's a loud roaring noise all the time, then your muffler probably has a hole in it, time to get a new full or partial exhaust pipe.
If the noise goes when it changes gear, then you've probably got a gear box or thrust bearing problem.
Apr 22, 2011 | 2000 Oldsmobile Bravada
I just bought a 2005 royal star venture. It's a great bike. The problem is a gear noise very loud when a ride in a constant speed. The noise become very loud and it very unpleasant after more than a hour....
Hi: It is "normal" for most royal star ventures to have a loud chirping sort of gear noise at certain rpms. Mine does it in every gear. It is especially noticable at between 100 and 110 kms/hr. If you increase or decrease the speed it gest better. This noise is because of the straight cut gears. Yamaha does this for strength and reliability but it is annoying. You can read more about it on the Venture owners sites such as The Venturers or VentureRider.org. It is nothing to worry about but I know it is annoying. Mine does it too. The RSV has a few quirks like this. nothing serious but somewhat annoying. THe other common thing is that the speedometer reads about 7% high. Mine does and many do. However, it is a very smooth, and very reliable bike. Hope that helps.
Jun 11, 2009 | 2005 Yamaha Royal Star Venture
Loud clanking noise in gear if the clutch is not engaged
That is what happens when you try to shift gear with out depressing the clutch pedal while changing gears.
May 06, 2009 | 2004 Kia Rio
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Bachmann Ho Gp35 W/dcc, Wm 3579 Bac60708 Logo
148 people viewed this question
Top Bachmann Crafts & Hobbies Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
