Question about Vivitar Tablets & eReaders
MY TABLET WONT TURN ON
IT WONT POWER ON
My tablet wont turn on or charge
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
SOLVED: Why won't my tablet charge or turn on? - Samsung Galaxy ...
https://www.ifixit.com/Answers/View/.../Why+won't+my+tablet+charge+or+turn+on https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=My+tablet+wont+turn+on+or+charge
not saying any off this is going to work for you but read it anyway.
the reason i say this is because i had some one else with the same problem but it ended up it was the tablet itself was faulty.
Nov 29, 2016 | Tablets & eReaders
Wht if tablet does not turn off after u hold the power button
What to Do When Your Android Phone or Tablet Won't Turn ...
www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
May 16, 2015 - android wont turn on. You turn on your Android phone or tablet by pressing its power button - simple. If that button won't work, your device isn't necessarily broken ... often see an "empty battery" indicator on the screen when you try to turn it on. ... You should only have to hold the Power button down for ten ...
samsung tablet wont turn on - Samsung - Android Tablets - Tom's Guide
www.tomsguide.com/forum/id-2155281/samsung-tablet-wont-turn.html
3 days ago - 43 posts - ‎36 authors
Dec 16, 2015 | Tablets & eReaders
Will not boot-up or start
Hi there, If your tablet will power on, but won't boot up, then take a look through this:How to Factory Reset Your Android Phone or Tablet When It Wont Boot
If it won't power on at all, try out these instead:
What to Do When Your Android Phone or Tablet Wont Turn On
My Android Tablet Wont turn on Anymore And cant take the back off
If those do not help, then contact the manufacturer.
I post on behalf of HP.
Jul 29, 2015 | Tablets & eReaders
Will not boot-up
If your tablet will not power up at all, then take a look at these two pages, with have some methods you can try.
If on the other hand it does power on, but does not boot up, then try this one instead:
If neither of those help, then I would recommend contacting the manufacturer.
My Freelander PD90 tablet wont turn on
Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
Nov 17, 2013 | Umi FreeLander PD90 10.1 Inch IPS Screen...
Tablet wont turn on
Try to charge it by the original adapter as the PC USB output is not power full enough to supply charging for it
Apr 29, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 20, 2013 | Coby kyros Tablets & eReaders
Tablets & eReaders Logo
11 people viewed this question
Top Vivitar Tablets & eReaders Experts
rostit
robert
Electrical Engineers...
Are you a Vivitar Tablet and eReader Expert? Answer questions, earn points and help others
