Question about Arris Surfboard Gateway Sbg6580 Docsis 3.0 Wireless Cable Modem
How to change mtu settings
How to change the mtu setting
Isn't there an internet site where i can change my MTU settings on SURBboard sb5101, i need the settings to be at least 1364
It is not possible to change the MTU settings for cable modem... MTU settings are applicable only for ADSL connections like AtT or Verizon...
Dec 07, 2010 | Arris SURFboard® SB5101 Cable Modem
Cant find where to change MTU setting on the Belkin IP address website.
MTU settings can be changed only for PPPoE connections...
in router interface goto connection type > PPPoE > MTU settings....
click here to see how to open router interface connections...
Aug 17, 2010 | Belkin F5D8236-4 Router
I need to change the MTU settings
To change your MTU settings download a program called DrTCP (google for it) then change the MTU size of your Internet connection, try 1465 and keep dropping it until you get a figure that works...
You can also check out xbox support site for more information on MTU settings here
Feb 23, 2010 | Arris SURFboard SBG900 Wireless Router...
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
MTU settings
where do i go to change the mtu settin on a comtrend ct-5364a
Sep 11, 2009 | Computers & Internet
How do you change the mtu settings on a sb4200
Try to access the Web interface of your router. Access http://192.168.100.1 and look for MTU. I think it is set to 1500 by default.
Jul 06, 2009 | Arris SURFboard SB4200 Modem
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Jun 02, 2009 | Zhone (6218-I2-200) Router
Changing the MTU setting
Log into modem using 192.168.2.1 in your browser and go to modem utility through browser.
May 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Mtu
The modem (westell wirespeed)you have does not have is a old modem... that does have options to set the mtu settings. You need to change the modem. By the way why you need to set the MTU settings,.
Apr 07, 2007 | Westell Wirespeed LiteLine 6110 Modem
MTU
MTU, Partial Loss of Internet Connection, and Performance MTU (Maximum Transmission Unit) is the largest packet a network device transmits. The best MTU setting for NETGEAR equipment is often just the default value. MTU is sometimes presented as something that can be easily changed to improve performance, but in practice this may cause problems. Leave MTU unchanged unless one of these situations applies: 1. You have problems connecting to your ISP or other Internet service, and their technical support (or NETGEAR's) recommends changing MTU. For example, these services may require an MTU change: * Yahoo email * MSN * AOL's DSL service 2. You use VPN, and have severe performance problems. 3. You used a program to "optimize" MTU for performance reasons, and now you have connectivity or performance problems. * An easy solution to most problems is to change MTU to 1400. * If you are willing to experiment, gradually reduce MTU as described in "Details of MTU", below. How to Change a Computer's MTU Size Note: If you change MTU on one computer, it is likely you will want to change it on your other computers, switches, and routers, as well. Instructions for changing MTU on other NETGEAR devices is found in the Reference Manuals. The third party Dr. TCP software can be used to change the MTU setting. 1. Download it from this link, choosing the zip file or the exe file at the top of the page. 2. Run the utility. 3. In the Adapter Settings pull down, select the Ethernet driver and adapter used to connect with the network. 4. In the MTU box, type the MTU size you are trying. 5. Click in any other box, without changing the data there. 6. Click Save. 7. Click Exit. 8. Restart the computer. Details About MTU A packet sent to a device larger than its MTU is broken into pieces. Ideally, MTU would be set to the same ? large ? value on all your computers, routers and switches, as well as on all the parts of the Internet that you access. But you cannot control the MTU on the Internet, and in practice the optimum MTU size on your LAN is related to your hardware, software, wireless interference, etc. * Tweaking MTU size may work well in one situation, but cause performance and connection problems in others. * When network devices with different MTU settings communicate, packets are fragmented to accommodate the one with the smallest MTU. * Windows XP sets MTU automatically, that is, it optimizes computer MTU for you. This Microsoft article explains resolving lack of connection to a broadband ISP using Windows XP: http://www.microsoft.com/windowsxp/using/networking/learnmore/ppoe.mspx * Once a network device fragments a packet, the data stays fragmented until arriving at the destination computer. Setting MTU size is a process of trial-and-error: start with the maximum value of 1500, then reduce the size until the problem goes away. Using one of these values is likely to solve problems caused by MTU size: * 1500. The largest Ethernet packet size; it is also the default value. This is the typical setting for non-PPPoE, non-VPN connections. The default value for NETGEAR routers, adapters and switches. * 1492. The size PPPoE prefers. * 1472. Maximum size to use for pinging. (Bigger packets are fragmented.) * 1468. The size DHCP prefers. * 1460. Usable by AOL if you don't have large email attachments, etc. * 1430. The size VPN and PPTP prefer. * 1400. Maximum size for AOL DSL. * 576. Typical value to connect to dial-up ISPs.
Feb 19, 2006 | NetGear DG814 DSL Modem Internet Gateway...
Arris Surfboard Gateway Sbg6580 Docsis 3.0 Wireless Cable Modem Logo
19 people viewed this question
Top Arris Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an Arris Lands Phone Expert? Answer questions, earn points and help others
