Question about Pioneer PRO-710HD 64" Rear Projection Television
I need more bright because m tv is too dark i cant eaven see the image
I have plasma tv thats has been getting the pink bands across the screen when the image on screen is bright. It gets worse when cell light is turned up in addition to brightness.
You need to check all voltages there is a sticker on the back of the screen with various voltages these need checking with a digital meter.
Jan 06, 2016 | Samsung Series 5 51-inch PN51E530A3FXZA...
Why does my sanyo dp46848 screen go dark but whites are too bright?
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Jun 30, 2014 | Sanyo DP46848 LCD TV
Television Picture Problems
color wheel issues and lamp needs replacement
Jul 05, 2013 | Televison & Video
Image very dark
go nto the main setting and clear everything and reset it you will have to start from new but the brightness will improve
Apr 29, 2013 | Optoma MovieTime DV10 Multimedia Projector
Hi the tv started to go dark then it would be ok then dark and the same when dvds played do get sound now black screen nothing at all
Hmm
Looks like the back light or the driver circuit has failed.
If you shine a bright torch at the screen can you see a very faint image ?
If so then its the back light has gone.
If you cant see anything its the screen driver.
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Grundig GU19WDT 19 in. LCD TV
Cant change the bright of the sony trinitron (FROM THE REMOTE )
this is a problem with the sony tv set not your remote.
you can have a tech turn up the HV seting on the botem of your fly back and at same time have him do a diagnostics on the tv set.
Jan 09, 2009 | Sony RM-Y173 Remote Control
Images too dark or too bright
Metering has gone on the .Can you set the camera to Aperture priority or speed priority?Set to either permanently if you cane then you should get a standard exposure. The inside shots may appear dark, but all the information is there and a treak in an image editor will brighten them up. Cant do the same for too bright images though if they burnout then that's it. a repair is not likely got a birthday any time soon Got some one that luvs you enough to buy you the next one.?
May 20, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
JVC AV-27530 Sudden changes in brightness
This sudden changes in brightness are caused by the change in voltage inside the tv,not in the outlet in the wall but inside the set,The changes are an indication something is going wrong and it needs to be corrected,the set does have a brightness limiter but it only works when the set wants to get brighter than normal,You need the assitance of a servicer to correct this problem.
Oct 04, 2006 | JVC AV-27530 27" TV
Pioneer PRO-710HD 64" Rear Projection Television Logo
27 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
