Question about Philips 42PFL7403D/27 42 in. LCD TV
How to connect tv to theater system using easylink
2 Suggested Answers
  • 120 Answers
SOURCE: what is easylink connection? Wireless? HDMI?
The Easylink is Philips name for HDMI CEC which allows multiple HDMI devices to control each other with one remote.
As for the sound...it looks like there is only one audio out and it's in the form of coaxial cable which isn't very helpful.
What I would suggest is that you tap the audio coming from the input. So I'm assuming your TV is connected to a cable/dish box. Use the audio out from that to power your headphones or external speakers. This will likely mean you can't use the HDMI or will need a splitter, but at least it will solve your issue.
Posted on Oct 16, 2009
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
Just got Panasonic Home Theater and using Digital Audio cable along with HDMI cable. Cables are coneccted and when I do a speaker test all work fine. When I play my Wii the sound is coming out the Tv not...
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
Feb 26, 2011 | Panasonic SC-BT200 Home Theater Systems....
How do you attach an x-box to the yamaha natural sound home theater system dvr s200??
You need to use an optical cable to connect your xbox to your home theater system.
This can be done 2 ways
1) You can connect the optical cable directly from the xbox to the home theater system.
2) You can also connect your xbox to your TV by HDMI and then connect your TV by optical cable to your home theater system.
This has the added benefit of all the devices that use your TV being able to use the home theater system in the same way the xbox is using it.
Regards,
sjstore2
Dec 18, 2010 | Yamaha DVX-S200 System
I can't get the TV sound to play on the HT speakers
Ensure that you have an audio connection to your LG theater system from the TV, that is labeled as "audio out" or similar to "variable out" to an audio input on the LG system. You may use a pair of RCA type cables or sometimes known as composite audio cables. Then on the LG system, select the input to use that you connected your audio cables from the TV into. Disable the TV speakers. Decrease volume on the LG system, then increase the volume on the TV all the way up. You now can use the LG system as the master volume for TV.
Nov 12, 2010 | LG LHT854 Theater System
How do i connect it to my tv so i can have surrounf sound when watching tv
if you look at the instruction manuakl that came with the theater system:
http://www.retrevo.com/support/RCA-RTD3133-Home-Theater-Systems-manual/id/23608dj495/t/2/
under connections and set up there are two ways of connecting up a tv
hopefully your tv has a audio out phono jack
using phono jacks connect the audio out from the tv to the AUX in the theather system
then select AUX in the theater system and then press the surround button to select sound modes
if your tv does not have a audio out jack look for a optical digital out socket in the tv and then use that to connect to a optical digital in in the theather system
May 11, 2010 | RCA RTD3133 Theater System
What is easylink connection? Wireless? HDMI?
Oct 16, 2009 | Philips 42PFL7403D/27 42 in. LCD TV
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
No sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
Nov 23, 2008 | LG LHT854 Theater System
Philips 42PFL7403D/27 42 in. LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
