Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore 2661532 Washer doesn't work 3 lights are lit up on panel but dryer works fine
  • 262 Answers
SOURCE: plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Posted on Jan 04, 2008
huuum
  • 750 Answers
SOURCE: Controls locked
Hello
Welcome to Fixya
My name is Huum,
To disable the control lock, hold the OPTIONS and SELECT buttons at the same time until the control lock light turns off.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Dec 24, 2008
  • 7 Answers
SOURCE: Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Posted on Jan 30, 2009
SOURCE: Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Posted on Mar 05, 2009
jsrock516
  • 5911 Answers
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Posted on Jul 05, 2009
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
Kenmore Elite Electric Dryer, Model # 110.8586400, Control Panel Lights inoperative, But Drum Light works fine. I am going to try this procedure, Will let you know if it works. Jay/ Jacksonville Florida...
I followed that procedure, Taking the Electronic Control Unit out of the dryer, Blow Drying the printed circuit Board (PCB) Board out and reseating P3 and P4, Worked fine.. No moisture was found in the Drum area. I forgot to tag the TECH SHEET FOR this particular dryer . But punch in Tech sheet , Part # 8546206 into google, this gives Schematic and valuable Troubleshooting steps, The only thing i could not find was the pin to pin test on chekcing the individual switches on the main functions, Suppose to be 14 pins I only found 13. But in all drying the PCB board and reseating the plugs worked for me. Again the symptons were no Light indication on ANY button depressed but the drum light was on. Great Site, Not a first time user
Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
Control locked on my Whirlpool Duet GGW9250PW0.
(Tip Courtesy JSRock)
Sep 22, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet gas dryer has CONTROL light lit with malfunction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$#$#$
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer. It worked fine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%^^%%
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Contol Locked
Jul 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
15 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
