Dometic B2200 air conditioner fan works then compressor starts ok but does not cool
22yooper
  • 828 Answers
SOURCE: PROBLEM WITH DOMETIC RV ROOFTOP AIR conditioner
Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
Posted on Jul 24, 2008
  • 726 Answers
SOURCE: My Pinguina PAC T100P air
the compresser can stop working due to low gas left in the air conditoner also check for any blockages
Posted on Sep 30, 2008
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
motor1258
  • 6674 Answers
SOURCE: My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
Posted on May 30, 2010
Stops running thermostat
thermostat or relay module issue.
May 19, 2013 | Dometic Rooftop RV Air Conditioner
Red light on dometic B2200
if fan setting on auto too much voltage draw bad capacitor or motor
Aug 13, 2012 | Dometic Rooftop RV Air Conditioner
The airconitioner will not work in the cooling or the heating mode ,it starts up ok and the compressor cuts in the fan is working ok.
Hope the compressor getting high amphs due to capacitor weak or loose wiring.Check and replace the capacitor. If still your compressor cuts off, the problem is with your compressor. Thanks.
Dec 12, 2010 | Dometic Rooftop RV Air Conditioner
AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Mar 30, 2010 | Dometic Rooftop RV Air Conditioner
Dometic air conditioner not blowing cold air.
make sure fan on auto if ok and unit on cool check compressor coming on if ok bad cooling unit
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
Compressor not starting
Most likely it is a small round overload found next to the wires going into the compressor. If that one seems ok then the next thing I would check is the capacitor. Might need a start assist.ce5a8bd.jpg
Jun 10, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
