My Philips DVD Home Theater System HTS3372D will not work it acts like it has no power but when you first plug it in the fan spends for a second then stops it does not do anything and there is no power light
2 Suggested Answers
SOURCE: Home Theater philips HTS3372D/F7 change for regio Free
Turn on the player
With the tray open press:
99990 on the remote
Region 0 will appear on the bottom left of the screen ]
from http://www.videohelp.com/dvdhacks
Posted on Aug 21, 2010
How do i fix the dvd blue ray 3d player to load the dvd?
Most likely the laser is failing , try an audio CD if it works then it is a bad laser. A cd has much less data to read.
Aug 26, 2014 | MGD Top Quality Philips HTS3372D 1000-watt...
Doesn't turn on the dvd
What is needed is a multimeter and a screw driver to open the set. Check the continuity of the cord wire to the set, check through the fuse and check the power supply. If there is no power to the main panel then the power supply must be checked. If not the processor section can be faulty. Check the 5 volt rail to the processor.
Dec 21, 2011 | Philips HTS3372D Theater System
Could i hook this up to my dell cpu desk top
Why not? Standard audio connections can exist exist on PC's. What doess YOUR soundcard support? Follow the manual. Web search "connecting audio to PC"
Aug 21, 2011 | Philips HTS3372D Theater System
Does the model HTS3372D/F7 play both Blue Ray and DVD or just DVD's ?
If you web searched the question or for a manual you might find something like
http://www.p4c.philips.com/files/h/hts3372d_f7/hts3372d_f7_pss_aen.pdf
... which says "Plays it all
Play virtually any disc you want - whether they be CDs, (S)VCDs, DVDs, DVD+R, DVD-R, DVD+RW, DVD-RW or DVD+R DL. Experience unbeatable flexibility and the convenience of playing all your discs on the one device."
or
http://www.p4c.philips.com/files/h/hts3372d_f7/hts3372d_f7_dfu_aen.pdf
which says "If there are questions regarding our TV set
compatibility with this model 525p and 625p
DVD player..."
Um, no Blu-Ray.
Aug 07, 2011 | Philips HTS3372D Theater System
There is a dvd in the drawer and I can not get it to eject
If you have a remote have you tried that?
Check to see if the eject bay is jammed, all you need is a flathead screwdriver and a flash light, just pry it open a little bit, if its a minor jam it should slide out.
IF the bay power has shorted it will need to be replaced which can be difficult and pricey, If its an older model however I think it is just stuck, just give it a little pry and see if it comes free, my old philips dvd player does the same thing on a consistent basis, it just needs a little prod.
Feb 06, 2011 | Philips HTS3372D Theater System
Philips Home Theater - Annoying high pitch sound while on standby
I have the same problem with the same model, so obviously it's not a single-unit problem. My only solution, since taking it back isn't feasible at this point, is to have a DVD on play-pause so that it's not on standby. Waste of energy, so I don't do it all the time, only when I'm sitting in the room late at night making the high-pitched noise hard to ignore.
Apr 17, 2010 | Philips HTS-3555 System
Turn on the player
99990 on the remote
Mar 20, 2010 | Philips Audio Players & Recorders
Dvd player won't stay on
your unit sir or maam, it has a deffective parts you need to replace the parts the two channel of the power output ,because this parts is shorted,you need a good technician to fix it. and buy the parts to replace it
kira_ryuk99@yahoo.com
Jan 11, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Phillips 6500 home theater system
Turn the power off, and then unplug the home theater from the wall outlet. Plug it back in after about 30 seconds, and turn it back on. If it still won't eject, then the HTS needs repair. Philips will replace it if it is still in warranty.
Feb 23, 2008 | Philips HTS-6500/37 System
18 people viewed this question
 Grubhead
Grubhead
