Question about Sharp LC52SB55U LCD TV
Set up dolby digital output
No audio output from TV to AV via optical
3 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
Posted on Feb 21, 2008
dsacco86
  • 1077 Answers
SOURCE: No Digital Audio From Sharp LC-37D64U
Try changing the the Audio Setup in the Digital Setup Menu.
If you have your manual, go to pg 11 and pg 28 for Digital Audio Output. If you need a copy of your manual, here's the link.
http://www.sharpusa.com/products/TypeManuals/0,1083,127,00.html
Page 11 has info on the problem and page 28 to solve it.
If that doesn't work, I would try downloading the latest software to fix is problem. Page 28
http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=LC-37D64U&s_func_disp_id=27&x=42&y=11
Posted on May 23, 2009
Do you have to have an optical cord from receiver to tv..koss model ks3102..if not i have rca cords were do cords go.
HD broadcasts by TV stations are often broadcast in Dolby Digital. If your TV can output Dolby Digital or HD then you will need to have the TV connected to the receiver via either the optical in, or the coaxial in. If the receiver can get the Dolby signals via the Coaxial and the TV can send them via a Coaxial socket it should work. Don't forget to set your HD set to output Dolby signals. If the TV or Receiver can only send Dolby via the optical you will have to use that. Optical cables can be picked up cheap these days. I have seen them in pound shops!
Sep 09, 2015 | Audio Players & Recorders
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
I just purchased a Coby TV Model number TFTV 3255. I am very happy with the set. However it has only ONE audio output. The manual, on page 7, "coaxial output" ,an optical audio cable is required....
If it is a single output and looks like an RCA type, then I would say that the cable you would need is a digital coaxial cable. The optical input/output will have a different shape and is not as big of an opening as a digital coaxial input/output.
Mar 01, 2011 | Televison & Video
I have a Sharp Aquos with a optical output, i conected it to the tv optical input of the panasonic sc ptx7 but it doesnt have audio via optical,on the contrary via rca works perfectly.
hi,
check the following on ur tv
1. Press MENU to display the MENU screen,
and then press c/d to select "Digital
Setup".
2. Press a/b to select "Audio Setup", and then
press ENTER.
3. Press a/b to select "PCM" or "Dolby
Digital", and then press ENTER.
4. Press MENU to exit.
PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
Dolby Digital
The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital.
ok
Dec 20, 2010 | Panasonic SC-PTX7 Home Theater System With...
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • Xbox 360 Component HD AV Cable
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
Sep 28, 2009 | Audio Players & Recorders
Vizio SV470XVT will not output Dolby 5.1 from optical out..
TV's only will output 5.1 from HD stations. If you have a DVD player, XBOX 360, etc connected through HDMI, then the TV will only send stereo PCM through the optical out.
Jun 17, 2009 | Vizio SV470XVT 47 in. LCD TV
Hook up your Xbox to a Dolby Digital Decoder
Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround. Before you get started, make sure you've got the following: A digital audio output. A free optical digital input on your receiver. An optical digital audio cable. Digital Audio Output Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output. Free Optical Digital Input For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver. Ready to Hook It Up? Let's Go! Connect the digital audio output to your Xbox. Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver. Turn on your Xbox with no disc in the disc drive. In the Xbox Dashboard, select Settings. Select Audio. You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital. You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes. You will see Dolby Digital Enabled in the audio screen. Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Sharp LC52SB55U LCD TV Logo
59 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
