Question about Kenmore 88732 Top Load Stacked Washer / Dryer
Kenmore stackable washer/dryer 2661532 dryer works washer doesn't three lights on panel are on.
  • 262 Answers
SOURCE: plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Posted on Jan 04, 2008
praky16
  • 744 Answers
SOURCE: Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
Posted on May 25, 2009
housejess
  • 317 Answers
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Posted on Nov 04, 2009
erpaalai
  • 999 Answers
SOURCE: water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Posted on Dec 24, 2009
arikrom
  • 528 Answers
SOURCE: replace dryer fuse kenmore stackable washer dryer
THERE IS NO FUSE.
the dryer have few cut off element.
and if you have volt meter that can check continuity we can fix it our self :)
turn off main breaker to the dryer!!!!
open the front panel 2 screws (the panel b/w the washer to the dryer)
if there is metal plate now affront of you take it out also (few screws never count :) )
now you see there are several element (and also some cleaning can be done with vacume...)
i give you video that show how to check the elements
if it not good let me know... (don't forget to rate my help :) ) good luck
http://www.youtube.com/watch?v=HRKIU4LiS20&feature=related
Posted on Jan 05, 2010
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 417.99980120 stack washer/dryer won't drain.
Check for a kinked drain hose. Also, if it is an older machine it could have something stuck in the drain pump. The usually culprit is an under wire bra
Mar 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water under stackable washer dryer
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Plug in for washer on a Kenmore stackable washer/dryer
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 88732 Top Load Stacked Washer / Dryer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
