Question about Kenwood KAC-7202 Car Audio Amplifier
Pop 7202 power amplifier manual - Kenwood KAC-7202 Car Audio Amplifier
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
Where do i connect the power control wire to ? I have a kenwood amp kac 7202, I'm connecting it to a stock cd receiver in toyota corolla 2004
Hello sophnettliss,
Most stock receivers do not have a dedicated amp remote lead and your 2004 Corolla is no exception.
The amp remote can be connected to any switched and fused 12V + source including the OEM receiver accessory wire which is the gray wire in your receiver harness.
Hope this helps.
Oct 02, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Kac-7202 with flickering power light
did u start simple with checking your connections and after that you have gone in pretty far so did you check the heat sinks and mosfets look for small dents or divits and those ane the bad ones
Jun 26, 2009 | Kenwood KAC-7202 Car Audio Amplifier
The Red & Black wires connected to my AMP touched
You blew the inline fuse on the AMP power wire. If it was not fused "inline" you may have blown a fuse internal to the amp. Look on the amp(or consult the manual) for the location of fuses "internal" to the amp.
May 01, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Keep popping fuse
you got short in the curcuit
Apr 03, 2009 | Kenwood KAC-7202 Car Audio Amplifier
KAC-7202 will not put out sound. Put in other amp works.
When you switch on the amp did the main amp ic produce heat. If does not change the main amp ic.
Feb 13, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Off and On at mid and high volumes
sounds like you have a problem with your grounding on you amplifier. check for shorts on your amplifier and the place where you have it grounded. (or check the power wire also.)
Nov 01, 2006 | Kenwood KAC-7202 Car Audio Amplifier
Keep poping the 40 amp fuse on the amps itself when the volume is up at all it seems
Your units drawing too much current. it could be a wireing problem, a speaker problem, or the amp has a problem. the correct way to troubleshoot this would first do or have the amp bench tested. Or you can remove all the speakers and wires and turn up the amp. If the fuse still pops,have the amp serviced. Good Luck
Aug 16, 2006 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood KAC-7202 Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
