Question about GE Audio Players & Recorders
Tape deck(component)SUDDENLY plays tapes slower - wouldn't a faulty belt gradually play tapes slower?
  • GE Master
  • 1,258 Answers
It could be a lose belt but also a motor is decaying or the capstan bearing has no oil in it. Many things can cause this problem.
Posted on Aug 02, 2015
SOURCE: TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Posted on Jun 20, 2008
robotek
  • 1512 Answers
SOURCE: JVC KD-85 Cassette Deck Stops in Seconds in play, REW., & FF
Hineovision1
The deck will need new belts and idler drives cleaned and serviced, and perhaps some idler tyres replaced. You can get a belt kit from these guys. replacing them is not such a difficult job if you have some mechanical aptitude. Just take it slowly, and focus on getting the transport out of the unit.
I am more than happy to answer any other questions you may have aboutit, please get back to me here, or use the ASK function to go straightto me :) If you are still unsure, have problems, or we need to look atthe situation more deeply, then before you give a rating for thisadvice, hit the ASK buttonThanks for using FixYa, If you consider the advice I have given you assound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regards
robotek
Posted on Jul 08, 2008
SOURCE: Sony tc-wr535 won't eject. Tape stuck. Won't play
The problem, according to messages on your site, is that the belts are old and have stretched. There is a great step by step tutorial on www.Instructables.com with pictures and all. Parts are not too hard to find on search engine. Looks like less than $25 to fix.
http://www.instructables.com/id/How_to_replace_the_belts_on_a_Sony_TC_WR535_Dual_C/
Posted on Jan 18, 2010
petraman7
  • 1175 Answers
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Posted on Mar 25, 2010
skywavebe
  • 1258 Answers
SOURCE: Technics RS-TR272 dual cassette deck
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
Posted on Oct 17, 2012
Denon tape deck ddr m30 will not play cassette, but fast forwards and rewinds fine, it just wont play!
There may be a separate motor for the play function and either it or a drive belt has failed.
Jun 17, 2016 | Denon Audio Players & Recorders
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
I have a tape which I'm anxious to play to convert to a CD, but it just won't play ! It will fast wind both ways but on play just shuts off. (It hasn't been played for a long time) It does...
If you wind the tape by hand (with a pencil or screw driver etc.)is the tape easy to turn or move from one end to the other with out any binds? If not It may be wound unevenly, smacking it down on a flat surface a few times on each side will usually free it up. Hope this helps.
May 17, 2011 | Audio Players & Recorders
I have a Sharp dual cassette deck, model RT-W800. I know it is a real oldie, but would still like it to work. Tape 1 does not turn at all, either regular speed or fffwd or reverse. Tape 2 turns but does...
OPEN THE UNIT CHECK THE BELTS PUSH THE PLAY BUTTON WITH IT PLUGGED IN WITH NO TAPE IN YOU SHOULD SEE THE BELTS TURN ON THE MOTOR AND THE SMAlLER THIN BELT AT TOP IF THEY ARE TURNING LOOK IN THE TAPE FRONT DOOR WITH IT OPEN AND IN THE PLAY MODE THE TAPE HEAD MECH SHOULD RISE WHEN YOU PRESS PLAY IF IT DOES NOT REACH IN AND PUSH IT UP GENTLY CARFUL NOT TO BREAK THE SMALL WIRES AT THE BOTTOM OF THE HEAD THEN STOP THE UNIT AND RETRY PUSHING PLAY IF THE HEAD COMES UP THE TAPE SPINDALS WILL TURN CLEAN AND USE TAPE HEAD LUBE ON A Q TIP ON ALL THE MOVING PARTS WHERE THE HEAD UNIT SLIDES UP HOPE THIS HELPS THIS HAPPENDED TO MINE I STILL USE THE UNIT WORKS GREAT
Dec 30, 2010 | Audio Players & Recorders
I have 2 and neither will play a tape. When you press play both make a strange noise
Is it the same tape every time or all tapes? If it is all tapes then it's more than likely a belt issue. The tape players have little rubber belts inside they sometimes get stretched when they are used alot. And they will make a whinning sound. They can be replaced.
Dec 12, 2009 | Tascam 112 MKIII Dual Cassette Deck
Playing a tape on Deck B stops after a few seconds. Tried over and it stops again after a few seconds of play.
Either tape is tight, run it ff the rev all the way back, or transport is failing , motor , belt , pulley etc,
check tape or try another one in deck b, how is deck a
Sep 21, 2009 | Onkyo TARW255 Single Dual Cassette Deck
Cassette player on mx-d302t
Hi As you know cassette decks have been around along time, and as such they are fairly robust. The vast majority of the time, problems like you are describing are the result of a broken drive belt, or bad capstan motor. This is not true for all, but if you have favorite tapes you wish to play, you need the deck fixed, and if the problem is drive belt or motor, the repair normally should not be hugely expensive. Hope this helps, good luck!
Feb 23, 2007 | JVC TD-W118 Single Cassette Deck
240 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
