Question about Brother MFC-9420CN All-In-One Laser Printer
My brother MFC9420cn has error mssg " check tray #1"
I have tried downloads , several calls to brother, new tray, unplugged, everything way too many times. I really dont want to pay a few $100 to fix a year old printer.
  • Anonymous Feb 11, 2008
    Same here:
    Check Tray#1
    Reinstall tray.
    This doesn't have anything to do with Linux printer drivers.
  • Ken Fox Mar 10, 2008
    I tried replacing the POE (paper out sensor) to no avail. I Also purchased and downloaded the Brother repair manual for this printer. Unfortunately, while the logic for thr paper out condition should be simple, it is not documented in thier service manual. Even more unfortunate is the fact that the service manual suggests that you refill or replace the paper tray to solve the problem.
    There are three sensors in the unit near the tray, of which one is identified as the POE sensor. I replaced this but it did not work. It's a realtivly simple photo sensor device operating on 5VDC that is contained in a fairly standard housing.
    To get at the sensor, you need to remove the right side cover (two black screws at the bottom) . Next you open the rear cover and remove the two screws on the right side which hold the hinge in place. You need to disconnect the cable that commects the main unit with the rear cover assembly. There is a ***** on the left inside of the unit which holds a limit strap for the rear cover. disconnect this ***** and its bushing. becareful as it is under tension and likely to fly away. pull the rear cover directly out the back of the unit and slightly to the right side. There are two stubs that will snap closed under spring tension, so whatch your fingers.
    Next there is a paper feed assembly on the rear of the unit. There are two silver screws holding it in place, they are recessed. The manual says to disassemble the feed/guide assembly to remove it but I did not have to.
    The paper sensor assembly is on the lower right side as you face the rear of the printer unit, next to the paper feed wheel. there are tow recessed silver screws that need to be removed, and then it will slide straight out.
    There are three sensors on the assembly. DIsconnect the three wire connectors (rembering which is which for reassembly) from the unit. The sensor on that was rear most on the assembly and the POE sensor are Idenitical and share the same part number. They just snap in.
    To remove the POE (paper out/tray ) sensor , you also need to remove the small circuit board from the assembly by removing the two silver screws. Once that is out of the way you can unclip the sensor and replace it with a functioning one.
    One irritating issue is that there are no idenitifying markings on either LED or what appears to be a photo transistor - which would have made troubleshooting far easier. Additionally, while various other printers have similar photosensors, the pinouts on the connectors are DIFFERENT, and cannot work without modification.
    As I said in the beigining, I swapped an Identical sensor device (same part number) from elsewhere int he printer but the paper tray error is still showing.
    This is not a driver issue because none of the standalone print functions or faxing functions work at this time.
    Brother tech support says that installing the lower tray will not allow me to circumvent the problem but I am going to try it seeing as thier service manual has been fairly useless in troubleshooting this problem although very useful in the disassembly of the unit itself.
    Anybody with any ideas would be welcome
  • 3 Answers
Check the total page count in the menu. If it reads 288888, you have a defective engine board and it needs to be replaced. It is neither a driver issue nor a problem with the paper cartridge.
Brother will quote you a price in excess of $600 for a new engine board, but some authorized repair shops can get them for less than $200.
Posted on Apr 01, 2008
  • 1,006 Answers
The printer wont printer and displays "Unable to Print. See Troubleshooting and Routine Maintenance Chapter in Users Manual"
Unplug the printer for about 15seconds and then plug back in and power up.......this should reset the error code! Test print and you should be good to go!
Oct 05, 2014 | Brother Mfc9420cn Mfc-9420cn Fax Modem...
MFC9420CN brother printer says Check tray #1 Reinstall tray
I had this same problem. The solution was resetting it, and the instructions below worked for me:
2.3 Parts Life Reset Function
This function is provided for service personnel in order to reset the counter of each periodical replacement part and count the number of replacement times when replacing the periodical replacement parts.
(1) Press the 3 and 9 buttons at the same time in the ready
(2) The "Reset Menu" will appear on the LCD. Select the
applicable periodical replacement part by pressing the up arrow or down arrow button and press the OK button.
- Drum - Belt Unit - PF KitMP - PF Kit1
- PF Kit2 - Fuser - Laser
(3) When the OK button is pressed the "1. Reset 2. Exit"
appears on the LCD. Press the 1 button if resetting the
counter. If not, press the 2 button.
(4) Pressing the 1 button accepts that the machine implements
the counter reset.
(5) If the 2 button is pressed the machine goes back to the
select part counter again. If you need to Exit press the
Stop/Exit button at any time.
(6) The machine returns to the ready status.
Mar 03, 2011 | Brother MFC-9420CN All-In-One Laser...
Our mfc5460 brother printer is giving the error message "print unable 30" and "print unable 50" alternately. WE had a paper jam, removed everything we could see from top and back, and are now stuck. We...
  • Remove the input paper tray and take off the output tray. Remove all loose paper from the input tray.
  • Step 2Pull out the paper support flap and unfold it to its greatest length.
  • Step 3Flip through the stack of paper before inserting it back into the input tray. Place the paper in the tray and adjust the paper guides so they press against the margins of the paper.
  • Step 4Ensure that the stack of paper is below the maximum paper line on the inside of the input tray. Unplug the power cord from the back of the printer.
  • Aug 09, 2010 | Brother MFC-5460CN All-In-One InkJet...
    Problems printing to Brother MFC 8660DN printer
    Pull the paper tray, likley a small black lever to the left of the roller called the edge actuator is dislodged and hanging down. When in position the actuator should easily push up and appear flat next to the roller.
    Dec 09, 2009 | Brother MFC-8660DN All-In-One Laser...
    Cannot Complete the MFL-Pro Suite Install
    Hello !!
    Thank you for choosing Here's my suggestion:
    - Go to the below mentioned link & download the uninstaller for MFC9420CN, Download this utility on your Desktop.
    - Now unplug the printer & run this utility to remove the software from the Vista Machine
    - Now reboot the machine & configure the computer in clean boot state.
    to do that follow these :
    To perform a clean boot on a computer that is running Windows Vista, follow these steps.
    1. Click Start vistastartbutton.jpg, type msconfig in the Start Search box, and then press ENTER.
      securityshield.jpg If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
    2. On the General tab, click Selective Startup.
    3. Under Selective Startup, click to clear the Load Startup Items check box.
    4. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
    5. Click OK.
    6. When you are prompted, click Restart.
    Once you have rebooted the machine, Try to install the Software.
    Hope this would help.
    Sep 03, 2009 | Brother MFC-7220 All-In-One Laser Printer
    Error Message "Check Tray #1 - Reinstall Tray"
    this is a hardware problem with there crappy printer .. and the fact is that it cost more ot fix it then to buy a new one ... I believe they set it to a certain amount of time and freeze up so ppl can buy a new on or the part or it
    Jul 27, 2008 | Brother MFC-9420CN All-In-One Laser...
    Brother MFC9420CN Toner Error-Incompatible Toner Detected
    Since this machine takes TN04 cartridges, and there are no chips or anything, do a reset.From memory press 1 and 7 together, then 1.
    Apr 10, 2008 | Brother MFC-9420CN All-In-One Laser...
    Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
    Via the control panel (This is a Factory Reset)
    1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
    2. Press the Menu or Menu/Set key on the control panel.
    3. Press up or down navigation key to select LAN and press Set or Menu/Set.
    4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
    5. Press 1 to select "Reset".
    6. Press 1 to select "Yes".
    7. The machine will re-start, re-connect cables once this is complete.
    Jan 21, 2008 | Brother MFC-9420CN All-In-One Laser...
    Re install tray will not clear
    OK, we never found a battery locally, but we tried something else. WE removed the battery and left it out for several hours. Our thinking was we were trying to reset the memory somehow. Well, it worked. We put the same battery back in hours later and the check tray msg. went away. The printer still works fine almost 24 hours later.
    Oct 23, 2007 | Brother MFC-9420CN All-In-One Laser...
    Brother MFC-9420CN All-In-One Laser Printer Logo
    803 people viewed this question
    James Cagle
    James Cagle
    Jim Keysor
