Question about Panasonic SC-AK640 Shelf System
My Panasonic SA-AK200 won't read any cd's...
Radio works fine, but the 5cd changer won't read any CDs. It just skips through...
simplemitch
  • 752 Answers
SOURCE: Panasonic SA-AK95 (cd changer)
F61 is a power source error. If it got water in it, it's a paper-weight. There is NO repair for water damage...
Posted on Sep 22, 2007
  • 6 Answers
SOURCE: Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Posted on May 01, 2008
  • 4234 Answers
SOURCE: sa-pm29 cd-changer jammed
The loading mechanism needs to be rebuilt. There is also an engineering change that should be applied to this unit if it hasn't had the mod already. This is not a home repair. This unit should go to an authorized Panasonic service center.
Dan
Posted on Jul 29, 2008
welcomejee
  • 10594 Answers
SOURCE: SA AK200 does not appear to turn off completely
HiFi system actually turned Off when you press power button and display of hello, heavy, vocal etc is demo mode of this system and it activates when unit goes to power off.
You can change its settings like not to show demo mode etc and this procedure is described in owner's manual.
Thank you.
Posted on Dec 15, 2008
SOURCE: Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Posted on Dec 06, 2010
I haven't had a problem with my Bose Wave radio/one-CD changer. It's a 1995 model. The radio is fine, but in the past year or so I have problems playing CDs. They skip horribly, if
Use a cotton swab and isopropyl alcohol. Wet the end of the swab and gently rub the top of the laser lens. Let it dry for a few min and then try playing the cd again.
Nov 07, 2017 | Bose Audio Players & Recorders
Panasonic 5cd mod.# sa-ak18 won't play why
Presuming that other sources work okay and the the cables are connected correctly.....Try a CD Lens cleaner.
If that doesn't work then it's time to open up the unit and manually clean the laser lens. If that still doesn't work then the laser might be dead. Replacement parts may be available. Whether or not you can do this as a DIY repair though is questionable. It depends on your skill.
Sep 16, 2014 | Audio Players & Recorders
Bush Mini System with iPod Dock and 5 CD Trays the 5 cd changer tray is jammed the cds have came out of place and when pressing the eject button nothing happens
my bush mini 5cd ipod system wont stay on fm radio station when i turn it off at mains then back on its on mw this happens every time help
Aug 11, 2013 | Car Audio & Video
Hi I am having problems with my Panasonic SA-AK200 stereo system when in AUX mode. What happens is when I play through AUX mode The Sound only comes through One speaker usually the right one but when on cd...
Looking at your question, it appears that the problem is not always on the same channel (right/left). This makes me wonder if the problem is the source or the cables you are using. The easy way to test this is to connect everything, check which speaker is not working, then swap the left and right cables at the aux jack. If the same speaker does not work, then it is a problem with the SA-AK200. If the problem switches to the other speaker, the SA-AK200 is not the problem and you should try replacing the cables or suspect the source (whatever you are trying to connect to aux) is at fault. If the SA-AK200 is the problem, I would suspect bad solder connections at the input jacks. Good luck
Dec 12, 2017 | Panasonic Audio Players & Recorders
CD Changer not reading CDs
2000 bmw 528i,my cd changer also reads no cds,this seem to be a common problem with all bmw cd changer.Anyway i removed the cd changer from my car,took the outside black cover apart only to see that a white big wheel came of its place,(its the wheel that holds the cd in place from the top (bottom wheel is black attached directly to the motor,as the cd is sandwitched between the black,and white wheels) .if that wheel is out of place the cd will not turn inside the changer for the eye to read it,so your radio screen will read NO CD OR NO DISC.Very easy fix,just place the wheel in its place,and everything worked fine,it took me 20 minutes to fix.
p.s :
1- you do need to make sure you have an original cd in for testing it.
2- you do not need to recode your cd changer at the dealer if you have an old bmw,dealer will need to recode cd changers for 2006 and up.
Good luck.
Jun 15, 2009 | 2001 BMW 3 Series
Cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
May 24, 2009 | Panasonic SC-AK78 CD Shelf System
Nov 26, 2007 | Panasonic Audio Players & Recorders
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
43 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
