Question about Conair Home Spa Kit For Hands And Feet Paraffin Heat
Manual for conair parafin wax kit - Conair Home Spa Kit For Hands And Feet Paraffin Heat
I have a 2001 lincoln ls v8 my sunroof will slide back but when you close it it will close but it wont raise up to close all the way can someone help and tell me how to fix it
Start by making the tracks slicker with parafin, bees wax or graphite. If the motor is weak, you can run a larger positive wire going to the motor. If those don't work, you may have to replace the motor.
Jan 05, 2015 | 2001 Lincoln LS
How do I get my popper to stir? the heating element works but the stirring rod will start then stop and sometimes will not go again
oil and steam gets into the little gears and motor of this little device a lot , wreaks a bit of havoc with gears , i take mine apart and lube with parafin wax it lasts longer than other oils/greases and is food safe some lubes are NOT and cant be used with food stuffs with out someone getting sick
Dec 23, 2014 | Cuisinart EasyPop Popcorn Maker
How do I fix the drill press table so it moves up or down
most tables have a rack and pinion gear that raises and lowers them , if this is tight first ck that lock bolt has not been applied (next to crank handle) if ok then oil it , me i use parafin wax because i only use mine for wood and oil tends to stick the sawdust to it , so i use wax instead
Sep 19, 2014 | Drills
Can anyone recommend a good wax warming kit that I can use at home for hair removal?
I use the GIGI wax warmer as I found it really reasonable price wise and I think it does a good job. Amazon are selling it for around $22, see the link below;
http://www.amazon.com/GiGi-0225-Wax-Warmer/dp/B0030ZRS7A/ref=sr_1_2?s=beauty&ie=UTF8&qid=1352976928&sr=1-2&keywords=wax+warmers+kits
Feb 18, 2013 | Health & Beauty
The top fell off
you can download the manual at this website and see if you can find an answer to your problem
http://www.conair.com/cnt_ib.php?action=filter&type=category
Feb 13, 2013 | Conair Cpc225 Chrome Clipper Kit 21pc...
New bright santas christmas express no, 187 train wont smoke
This goes back about 40 years for me. Both Lionel and TYCO had "smokers" in their train sets. My recollection was that the "special smoke oil" was a mixture of very highly refined kerosene and parafin wax. Try a hobby shop such as Hobby Town or some such.
Nov 27, 2012 | New Bright 384 Holiday Express Animated...
Have a precor 9.20. After using about 15 min. I am smelling something like Maybe motor buring? Should I try to lubricate?
First, inspect the walking deck for damage (scratches, gouges, worn surface) and check the belt for wear. Feel the outer edge of the underside of the belt, then the center. The center should be rough like the outer edge. If it is smooth or fuzzy, the belt is worn out. If deck and belt are OK go ahead and lube the deck. I think Procor uses a standard parafin wax you buy at the grocery store, but check your manual to be sure. Apply the lube to the walking deck and try the machine again.
Feb 26, 2011 | Precor 9.21 Treadmill
Manuel for model #pb5 hand/wax therapy .Lost manuel.
google it or email the company i am sure they will help
Jan 23, 2011 | Conair Home Spa Kit For Hands And Feet...
Magnet on freezer door no longer functions to maintain seal
Make sure the door is not out of alignment,and nothing is preventing the door from closing properly, check for loose or broken door hinge..
Plz leave comment.Thanks.
Dec 25, 2008 | Freezers
Conair Home Spa Kit For Hands And Feet Paraffin Heat Logo
23 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Danny Kuhlmann
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
