Question about Swintec Office Equipment & Supplies
Wrong letter typed
Print wheel types wrong letter from keyboard
JUSTOLDJIM
  • 454 Answers
SOURCE: Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Posted on Jul 04, 2007
JayBlair
  • 328 Answers
SOURCE: Not typing correct letters
Open the top cover and look inside on the right and you will see a switch. There will be 3 positions. The one toward the rear is US.
Posted on Aug 12, 2007
  • 19 Answers
SOURCE: GX6750 Typing wrong letters
Linda,first of all,does the daisy wheel spin when the typewriter is first turned on? if it does,then you will feel assured that it is installed properly. Next, refer to your manual to key board settings. It will indicate that there are settings for normal standard English keyboard and somehow that setting may have been changed. It would be also be important to check the daisy wheel to see if it is compatible with standard English keyboard...Cheers, John
Posted on Oct 21, 2007
JUSTOLDJIM
  • 454 Answers
SOURCE: WHEN TYPING THE WRONG LETTERS PRINT
Keyboard 99 is Laten supplemental. Try holding down the code key and pressing the x key it should reset the keyboard.
Posted on Jan 26, 2008
  • 106 Answers
SOURCE: TYPES WRONG LETTERS
everythin is ok,you by a new wheel with letters and that wheel is for european market ,and y -z ar on the other sides
Posted on Feb 04, 2008
I began using my typewriter this morning...and when I press a number or letter...it types the wrong number, letter, or symbol. For example, I press the letter "F" and it types a number...
Turn it off and on it should go thru it's dance and rehome the print wheel. f you are notin KBII , language mode or the print wheel damaged the homing pawl for the P/W is probably broken you need a tech.
DickyO
Jun 09, 2011 | Brother SX-4000 Typewriter
WHEN TYPING A HALF SPACE IS SKIPPED OCCASIONALLY AND WILL NOT CORRECT THE LETTER TYPED, IS THE LETTER WHEEL REPLACABLE?
To answer your question yes the print wheel can be changed, BUT that is not your problem. The machine needs to be reset or the reset tab needs adjusting.
Background;
When you turn on the machine the print head moves to the right side, the print wheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
I would
  1. Power it off and then turn it back on and test to again.
  2. If it's still typing the wrong or unreadable letters then turn off the power open the lid. On the bottom of the case there is a metal frame on the right side of the frame you will see a small metal tab pointing towards the print head.
    1. (When the machine resets its self, it uses that tab as a reference.)
  3. That tab is easily bent which causes the reset to be wrong. Most people can bend it by hand, DON'T use a pliers! The tab can break off completely. It doesn
Nov 30, 2010 | Brother EM-430 Typewriter
Wrong letters are printed
The Daisy wheel is probably in wrong..reinstall it until it spins to the home position. Its either that or an adjustment to the print wheel motor.
Oct 07, 2009 | Swintec Office Equipment & Supplies
My keyboard does not display the letters I am keying
Just a little help from you. Does it type the wrong letters or not type some letters at all? Is the display right and print wrong or viisa versa?
DickyO
Nov 20, 2008 | IBM Wheelwriter 30 Typewriter
Lexmark 1500 typeover
There are a few possibilities, first check to see if it is in the language mode, light on the rt. side code "L" will get you out of it. If that is OK the keyboard may be selecting the wrong keyboard. Press and hold code key, press and release the "L" key, type 001, release the code key. If this solves the problem. check the keyboard connectors. If they seem to be fully plugged in you will need a keyboard.
DickyO
Sep 29, 2008 | Lexmark Wheelwriter 1500 Typewriter
Types wrong letters
It sounds like you have the 10,12,15,PS selector switch on PS with a 10, or 12 print wheel installed. Return to the left margin, move the switch to 10 and type.
Jun 25, 2008 | Swintec 7040 Typewriter
Oct 21, 2007 | Brother GX-6750 Typewriter
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
Cannot type letters.
Your T/W neads a new keyboard membrane, you cannot clean this type membrane so you will have to replace it.
May 26, 2007 | Brother GX-6750 Typewriter
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
