Question about Performance Teknique Car Audio & Video
Aux for performance tekquet - Performance Teknique Car Audio & Video
How do I reset a 2008 ford fusion stereo?
Hello Chad... As I'm not sure which SYNC Version you have, go here for info on "How To Perform A Master Reset"
https://owner.ford.com/how-tos/sync-technology/sync/settings/how-to-perform-a-master-reset.html
Jun 30, 2016 | Ford Cars & Trucks
Restricted performance mode xf
Did you actually check for voltage with a test light or digital multimeter? Did you check the ground circuit? I don't know much about your particular vehicle, but, the basics are the same, voltage and ground.
The diagram doesn't say aux, but, the basics are there.
Feb 11, 2014 | 2009 Jaguar XF Supercharged
I bought a second hand Fishman LoudBox Performer. The problem is that the Aux-in for the headphone doesn't work. So sick... What can I do? tnx
I don't understand your question. The "Aux in" is just that an input that goes to the power amp. Please note that the Fishman Loudbox does NOT have a headphone jack so don't be disappointed as there plain isn't a headphone jack on this unit. I would recommend that you get a small headphone amplifier for the purpose... or even go to a thrift store and get an old stereo system that has a headphone jack and use that.
Aug 01, 2011 | Fishman Loudbox Performer Amp Acoustic
Hi, I have just bought a R-H300 tape deck connected to a CR H250 amp. The play quality is good however I have connected a new mic through the Aux phono ports using a jack/phono converter and the record...
If your mic isn't made for connection to an AUX or Line Level input you won't get its specified performance.
Perhaps if you defined the mic and looked up a user's guide somewhere (retrevo.com comes to mind) you might find what you need to use it. Mic's usually require microphone preamplifiers.
Dec 29, 2010 | Teac Audio Players & Recorders
What to set the low pass frequency switchon the top of unit
to what you have explain your set is connected wrong find a qualified installer
Apr 02, 2009 | Clarion EQS560 5-Band Car Equalizer
Whinning noise when car is on and AUX is connected to ipod
ENGINE NOISE PLUG ALL YOUR RCA DIRECT TO AMP BYPASS EQ AND SEE WHAT HAPPEN IF THIS STILL HAPPEN CHECK ALL YOUR GROUND AND RCA MAKE SURE YOU HAVE GOOD CONNECTION
Mar 30, 2009 | Boss AVA-1215 5-Band Car Equalizer
Logitech keeps switching to AUX during IPod and radio listening
Hi, The Pure fi elite only support apple product up to the 3rd generation ( That does not include iphone 3GS ) Streaming functions are not supported on this hardware as the pure-fi can not detect the audio flux, it automatically switch off as there is no signal detected the Pure-fi go to sleep mode as if there were nothing connected to it. Ehrn the pure-fi as been designed the streaming apps from devices were not taken into consideration by Logitech, Unfortunatly there is no much we can do... Thanks and have a nice day ! J -
Dec 25, 2008 | Logitech Pure-Fi Elite High Performance...
DVD Recorder with dish network
most likely the auto tune is not going to work for this
Dec 28, 2007 | DISH Network IR Remote Control
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Car Audio & Video Logo
20 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
