Question about HP Computers & Internet
Battery will not calibrate
It keeps saying that it needs to and when I calibrate it, it says passed but needs to be calibrated again.
ginko
  • 19396 Answers
SOURCE: battery problem...
Sounds like an hardware problem. The battery charger does not depend from the operative system, and is working even when the computer is turned off and connected to power socket. Leave your laptop off and connected to power overnight. If the battery charge is still zero then you probably need to get a new or tested-second-hand battery.
hope this helps
Posted on Feb 15, 2008
  • 11 Answers
SOURCE: compaq presario 2500 battery calibration
Try resetting the bios. There should be a hole on the underside of the laptop with letters reading "RESET" in white text.
Stick a toothpick in there and hold it for a few seconds and then try booting up again
Posted on Feb 26, 2009
SOURCE: cant calibrate screen on i900 omnia.
put a blank file called welcome.not (make using notepad) onto the removable storage card this will bypass the startup screen and mean it does not jam into this look on startup
down load a file phm registry edit... (search on internet) put the cab onto the phone... in stall.. and run
set the sensitivity on this to 20, you can then calibrate the screen... you can try stepping it to 18 16 14 and 10..
this will cure the problem
Posted on Jul 26, 2009
  • 14 Answers
SOURCE: The new battery will not calibrate
do you know for a fact that its the right battery? if you dont then its most likely not and i would recommend going to batteries-plus.
Posted on Aug 24, 2009
  • 66 Answers
SOURCE: i have a toshiba satellite p105 and when on line
more than likely the motherboard or separate video card are failing.
Posted on Oct 30, 2009
Why does my tablet keep powering off when the battery says 82%
Battery is weak and not calibrating properly. Replace the battery and re calibrate unit as per the instructions that came with your unit.
Sep 15, 2017 | Tablets & eReaders
How do you "run the software calibration"?
  1. Turn unit on
  2. Pull out the safety key
  3. While holding down the 'start' and 'speed increase' button insert the safety key. Unis should now say calibration.
  4. Press enter on all options until screen does not change when you press.
  5. Press 'Start' (Unit will run auto calibration). If passed, the unit will reset itself. If fail it will say 'fail'.
  6. If you do not see 'fail' power off, then on again once done.
  7. You're good to go. (If unit says 'fail' contact service)
Techmotion Corp does service and repair in many north-east states. Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Jun 23, 2015 | RTO Sole F80 Treadmill
How to calibrate my tablet
You need to keep doing it till calibrated, happened to me but got it after a while.
Jan 15, 2012 | Archos 7 home tablet
Problem with the HP LaserJet 4730mfp All-In-One Printer Unable to use ADF. Red light under start button.
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Aug 30, 2011 | HP LaserJet 4730mfp All-In-One Printer
Zebra S400 does not keep the calibration settings. After calibrating or restoring factory settings (like described in the manual) first label prints OK (using BarTender software) then it's off again. Same...
After you calibrate the printer. Press feed a few times. If it feeds a single label each time, then the calibration was successful.Power off and on while holding the cancel button. (config printout). Keep config for reference. Send label print from computer. If it does not work, then check that the printer driver matches the config printout. The computer printer driver will change and overide the settings in the printer
Apr 29, 2011 | Zebra Stripe S400 Label Printer
CANNOT CALIBRATE XBOX 360 SHRED BOARD. kEEPS SAYING "something didn't go through, lets try it again
I had the same problem. Do not use the batteries that come with the board. Use slightly older ones. After switching the batteries re-calibrate the board and that should do the trick.
Dec 25, 2010 | Activision Tony Hawk: Shred
Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jul 15, 2010 | Proform Exercise & Fitness
Tread mill is on incline. how can i adjust to a flat position
I am assuming this a Icon product and this is the calibration sequence.
1) Press the Stop and the Speed Up keys down while inserting the safety key. Calibration Codes” for key sequence instructions to enter calibration.
Jun 27, 2010 | York Exercise & Fitness
When you turn on treadmill the incline goes all the way up and all the way down. Does nothing else.
First we need to do a calibration follow this procedure
THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad Call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
May 29, 2010 | Proform 675 E Treadmill
System diagnostics says needs battery calibration
battery calibration is nothing but it the process to discharge the battery fully.
discharge the battery fully till the system gets off automatically, then only recharge the battery for 100%. make this process for 3times continously
Dec 24, 2009 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
12 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
