Question about Sewing Machines
Horn sewing table lift stuck
Lift mechanism is stuck either up and wont go down or down and cannot go up
2 Suggested Answers
  • 185 Answers
SOURCE: EZ-Lift Mechanism for Sewing Cabinet
Try this place, I have had good luck with them.
http://www.leevalley.com/hardware/page.aspx?c=1&p=41821&cat=3,48759&ap=1
Posted on Jun 03, 2008
When i release the leg lever to let down the presser foot ,the foot wont release all the way and now it wont stitch
Mine does this too sometimes. Lift up the head and look in the middle of the oil pan. The knee controller runs through there. Make sure the black knob is not stuck. Hit the knee thing a couple of times to make sure it is not stuck. It should move freely up and down. That may fix the problem. If not, look st the small post to the left and behind the oil intake. Move the manual presserfoot lever on the machine to see it move. It will be stiff, but it should still lift a little. Usually jigging these two parts will fix the problem. Good luck..
Mar 22, 2016 | Juki DDL-5550 Industrial Straight Stitch...
Needle stays down, will not come up.
sounds like the machine froze up, machine needs to be serviced
Sep 25, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
Juki ddl 555 knee lifter is not lifting the foot. How can I fix it?
I imagine that it is the mechanical knee lift that you actually lift with your knee? Sometimes the screw that holds the knee lift rod comes loose a little and starts to slide in the holder. Sit on the floor where you can see the underneath of your table and use a wrench or vise grip to loosen the bracket that holds your knee lift bar with the pad on it. Move the bar to the left and retighten the screw and I think you will be ok. Sometimes if there is too much oil in your pan or you have moved the machine and some of the oil spilled out, a little oil gets out of the pan onto the bar and makes it start to slip. If that doesn't work we'll try something else.
Jun 13, 2014 | Juki MO-644D Mechanical Sewing Machine
I have a Bernina Activa 145S; the pressure foot is stuck in the down position; how do I lift it?
Machine will require service from an authorized repair technician.
Presser foot mechanicals are broken.
Jan 30, 2014 | Sewing Machines
Bobbin stuck on bobbin winder spindle
you might have to use some force but not enough to break
the bobbin winder spindle. it's also possible that there is something
wrong with the bobbin for it to get stuck on the bobbin winder spindle
like that.
Nov 29, 2012 | White Sewing 2037 Mechanical Sewing...
The belt on my consew 7360 sewing machine wont turn handwheel when pressing foot pedal to stitch.
Your belt may be to tight you can loosen the belt at the wheel under the table. Loosen the screws and shift so the belt loosens.
Nov 14, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I have a horn cabinet bought in 1987 and I can't
The old Horn lifts had vertical rails on the sides and the newer style has one center support. Push the lever up and press down on the platform to lower, push up on the lever and the platform should raise. If it binds, the plastic slides are broken or if the cables are loose, then the lift is likely broken. www.hornofamerica.com
Jul 29, 2011 | Sewing Machines
I need a manual for my necchi sewing machine. IT is cast iron and the machine lifts up from the centre of the table. It was my mother-in-law's and I do not know wht model it is. I am guessing on the model...
Contact Allyn International in Denver Co. They are the importers for Necchi and should be able to give you your closest dealer or sell you the book themselves. Their Phone is: 1-800-525-9987
Oct 16, 2009 | Necchi 3101 Mechanical Sewing Machine
Janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Feb 25, 2009 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
