Question about Car Audio & Video
Car cassette tape player won't load tape, just stays in the eject position
  • 83 Answers
SOURCE: car cassette player
yes the rubber rollers inside your unit have become hard,,and they are slipping, and the unit detects this,, u can purchase a product called re-grip [ for rubber products and it treats the rubber in such a way to make it soft and pliable again ] the product is sold by mcm electronics and can be found online,,, treat the surfaces of the rubber rollers in your unit and it should preform to original specs....any further help please email me at troublerst@hotmail.com...i hope this helps you
Posted on Jul 12, 2007
SOURCE: Will Not Load Cassette
I have the zr850 which I have used less than a dozen times, and it does the same thing as you describe. Was told by canon tech people to try a maxell brand tape and a head cleaner tape. Have not tried their sugestion yet. camera is 3 months old.
Posted on Aug 04, 2007
  • 6 Answers
SOURCE: cassette loading - keeps on ejecting cassette
The "remove cassette" problem on Canon DV cameras is a general fault error that can be induced by many varied problems from faulty dew sensors to jammed mechanisms. These mechanisms are small and delicate and it does not take much to stop them working. If the head drum is starting the next thing that should happen is the capstan spins which in turn drives the take-up spools when the cassette loads. Tape tension problems (other than a broken tape) would not be detected until after the capstan is running. With the battery removed and the cassette door open, CAREFULLY attempt to rotate the capstan spindle. I use a small rubber insulating sleeve stretched over a small screwdriver. If this does not solve the problem then other possibilities are that the printed ribbon cable from the cassette mechanism to the camera needs re-seating or perhaps the capstan drive motor is faulty. However, try and look for the obvious first. To investigate further by dismantling is extremely difficult and I would not recommend it unless you want to risk writing-off your camera completely. I have done this operation (successfully) as a last resort and found that re-seating the printed cable in its socket solved the problem, however, I would not recommend or suggest this decision be entered into lightly. Its a good feeling when you get it working again but sickening when you have to allocate it to the re-cycle bin. As I say, this fault indication has many causes. Getting it serviced by Canon is not an option as the cost would exceed its value so unless you can find a local repairer that's prepared to look at it, then you have very few options.
Posted on Dec 18, 2007
SOURCE: loading tapes
Hello, exact same problem here, closes fine when no tape inserted, but with a tape, the camera won't close, just keeps ejecting the tape.
Another problem that I encountered is that the camera will not take pictures anymore.
When I press the button, it beeps, but there appears a green dot on the screen,
My handbook tells me, when this dot appears on the screen, this means he camera will not take a picture, it however doesn't tell me how to solve the problem.
Anybody
Posted on Jan 05, 2008
SOURCE: CAssette Player screech
buy a new head unit thats wut i did
Posted on Oct 11, 2008
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Vhc tape is stuck in my video cassette recorder, it is a much older vcs, is their any way I could possibly that I can get it out without breaking the vcs?
Take ur finger senses all around the VCR the open flap door for sensors also pushes the eject button too as the same time,when the right sensors it hit ur finger the VHS tape will come out.
Mar 16, 2011 | Zenith Televison & Video
Tape loaded normally but now won't eject. The unit just powers off after a few seconds.
Unplug the power from the combo unit and give it 30 seconds, now plug back in, sometimes this will eject the tape, if not! take the top off the machine and check to see if the tape is spewed in the mechanical section and around the video head, if yes! get a pair of scissors and cut the tape carefully to avoid damaging the video head and remove all tape deb-ri, now power up and eject the main cassette. But! if you find the cassette has loaded in place and the tape is still in the vhs cassette, this would indicate a loading problem with the main carriage, broken belt, bad idler assembly and possibly sensor issues.
Feb 06, 2011 | Sony SLV-D350P DVD Player/VCR
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Cassette ejection mechanism not working
pull the player and have it repaired, sounds like the belt is no good for the tape drive loading mechanism.
Apr 13, 2009 | 1999 Ford Taurus
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
