Question about Magellan GPS 310 GPS Receiver
GPS will not hold correct time
I can't make my Magellan Pioneer hold the correct time neither using Ez  nor correcting using MENU options. It keeps making errors no matter how often I correct it.
Re: GPS will not hold correct time
Must sett up in ez.. use grenish mean time for your location  not daylight saving  sorry about the spelling
Posted on Oct 30, 2007
0 characters
3 Points
How toset the time ona magellan triton 400
Do a MENU>>VIEW>>SETTINGS .. go do the menu as the time and day are hidden from the original screen .. Date and Time will appear .. highlight it and make your corrections.
Nov 04, 2010 | Magellan Triton 400 Handheld GPS Receiver
Magellan road mate 800 locked
that's great..where are you planning on buying this, as the passcode is specific to your region.
Feb 26, 2008 | Magellan RoadMate 800 GPS Receiver
I have not used my Magellan Maestro 4040 in quite some time and I charged it today for 4 and 1/2 hours and can not get it to turn on.
Hi davidhcaldwe
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Standing Member of G.O.T.
Oct 28, 2010 | Magellan Maestro 4040 GPS Receiver
My gps touch screen does not seem to operate.I have tried resetting many many times.
try the calibration screen in the options menu and follow the directions...make sure you hold the screen over the X until it moves to the next position.
if that fails, you might need a digitizer...let me know and ill help you
Oct 03, 2010 | Magellan RoadMate 1412 Car GPS Receiver
How do I set the time on the Magellan SE4
The default settings on this unit is to use the default time zone. This happens to be set to GMT (Greenwich Mean Time). I changed it to local as follows:
Press the tools icon at bottom of screen off the Menu Press System Press Time Zone Press Use Auto Time Zone to "uncheck" the default setting Press Set Time Zone to get choices Scroll up and down and find a big city in your time zone Select it by touching it I turned off Daylight Savings Time to get mine to set correctly Press the arrow back and you should see your time set correctly now.
Dec 03, 2009 | Magellan GPS Devices
Magellan GPS Pioneer will not hold onto satellite signal
I had the same problem. Found this link
As suggested at the end of the above thread I left my unit outside for a couple of hours and it suddenly sprang into life. Now it reliably gets a fix in 2 to 3 minutes when I switch it on.
My theory is that because it is only a 2 channel unit it takes hours to acquire a fix when the memory is blank.
The manual says it will keep it's memory for a month without batteries.
So if you leave the batteries out for more than a month, or move it more than 250 miles and then switch it on expect it to take a while to first fix.
Otherwise it's a nice little unit.
Mar 15, 2009 | GPS Devices
Canada map
Enter MAIN MENU then select USER OPTIONS then select REGION and select CANADA.
Jan 04, 2009 | Magellan GPS Devices
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Magellan Maestro 3200 GPS - wrong time on unit
My Megellan Roadmate had the same problem the time was way off and the date read 8/06/2009 instead of 06/17/2009. I tried everything the previous posting mentioned to no avail. I called Magellan tech support and they talked me thru it. (1) Turn the unit on outside ( not in a building ) (2) Hold down on the power button for 20sec. then let go. (3) Turn the unit on and go to the map. (4) Touch the upper rt. corner were the bars are, the screen will change and say tracking X (#) of sattilites. wait untill the bars for the sattiligts all change to green now you can go back to the main menu and the time should be correct.
Jan 01, 2008 | GPS Devices
Magellan GPS 310 GPS Receiver Logo
147 people viewed this question
Top Magellan GPS Devices Experts
Roni Bartlett
Roni Bartlett
Level 1 Expert
Chris Hunt
Are you a Magellan GPS Device Expert? Answer questions, earn points and help others
