Question about Bose 321 GS series II
Display on my bose 321 gs series 2 only displays a series of2 rows of symbols and no data or usable information
Siliconchip
  • 52 Answers
SOURCE: BOSE 321 NO DISPLAY AT ALL
Hello Fousea,
Guru Techman is right. It could be the thermal cutoff inside the transformer. If your 321 however is the latest version, they have a habbit of blowing the fuse and MOV on a PCB inside the sub box.
if you got lucky, its all you have to replace. Power of your head unit comes from the sub box through a square connector esp type cable.
Hope This Will Help. Good Luck
Posted on Dec 28, 2007
  • 21 Answers
SOURCE: bose 321
3 audio inputs (3 analog, 3 coaxial digital, 1 optical digital)
2 video pass-through inputs (composite and S-video)
Video output for TV (composite, S-video, and component)
Media center • 3 1/4"H x 13 3/4"W x 10"D • (8.3 x 34.9 x 25.4 cm) • 6.7 lbs. (3 kg)
Remote control • 1 1/8"H x 2 1/2"W x 9"D • (3 x 6.5 x 22.9 cm)
Gemstone speakers • 2 1/2"H x 5 1/2"W x 4 1/8"D • (6.4 x 14 x 10.5 cm) • 1 lb. (.45 kg) each
Acoustimass module • 14 1/2"H x 8 3/4"W x 19 1/8"D • (36.7 x 22.2 x 48.5 cm) • 23.3 lbs. (10.6 kg)
Total shipping weight • 44 lbs. (20 kg)
gray_hr.gif What's In the Box • Acoustimass® module • Media center • 2 speakers • 3·2·1 universal remote control • Setup DVD • Antenna stand • Stereo cable • Video cable • Speaker cable • Module cable • Rubber feet for Acoustimass® module • Rubber feet for speakers • Batteries • AM antenna • FM antenna • 120V power cord • Quick setup guidepls rate !!!!!!
Posted on May 29, 2008
freetek
  • 5568 Answers
SOURCE: Bose 321 won't turn on
I'm amazed at the range of comments regarding this system; they range from unbridled enthusiasm to some **** words.
Before I try to help, if I am not familiar with a specific model but have a clue to what the nature of the problem might be, I research the item to see if I find some support for my suspicion.
You might keep tabs on some comments I found relating to a possible class-action lawsuit due to the array of problems that have appeared with this system.
This link will give you a sample of them:
http://www.amazon.com/Bose-DVD-Home-Entertainment-System/dp/B0002JY6SQ
Posted on Oct 17, 2008
SOURCE: I have a sony PS3 and a Bose 321 gs series 2 sound
u have to go to radioshackand get a 1/8 to dual rca y-adapter then u plug it in to ur tv , if its a philips like u say itis it has a audio out put for headphones on the left bottom corner on the back of the tv, just plug it in and then lower the volume on the bose system and on your tv remote press menu, tv menu will come on on the tv screen go to it, or press ok on the remote, on tv screen will say tv setting press ok on remote, go to sound, go to headphone volume, put it on 60 its the perfect setting on for your tv DO NOT go over 65 it will distotion the equilizer on the bose, well this work for me but if i find out an other way ill let you all know
Posted on Apr 04, 2009
  • 118 Answers
SOURCE: bose 321 will not play DVD DISPLAY READS FORMAT
please insert non-bootleg copy
Posted on Nov 03, 2009
Bose 321 device code for Kogan UHD TV
Your Bose remote may not work with your Kogan TV.
Aug 12, 2016 | Bose 321 GS series II
Power cord is broken on my bose 321
Is the power cord bad, or the jack in the unit that you plug the AC cord into broken? If you're interested in repairing your Bose, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 22, 2014 | Bose 321 GS series II
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
My Bose 321 read see TV, but the TV does not display anything?
I'm sorry, can you please rephrase your question? I don't understand your question
Aug 25, 2014 | Bose 321 GS series II
Blew fuse bose 321
When a fuse turn black, you have a serious short inside. Repalcing the fuse will do nothing. For more information, please visit my website at audioserviceclinic.com. You may contact me directly through the website.
Feb 06, 2014 | Bose 3 2 1 GS Series II DVD Home...
Bose 321 will not power up
Does the unit show any lights, or do you just have no sound? If you have more questions, or would like to inquire about having you Bose repaired, please visit my website at audioserviceclinic.com. Thank you.
Nov 24, 2013 | Bose 321 GS series II
Bose 321 series wont play region 1 dvd
To convert Bose 3-2-1 GS Series 2 DVD system to Multi-Region playback
1. Press the Right button on your remote control
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject twice to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on.
Done!
Nov 29, 2010 | Bose 3 2 1 GS Series II DVD Home...
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
THANK YOU!
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Bose 321 GS series II Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
