Question about Maytag Legacy Series Top Load Washer
Replacing water pump mayteg sav205daww - Maytag Legacy Series Top Load Washer
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: remove the front of the washer
I have never messed with one of these with 2 front panels but it looks to me like you remove the 2 screws at bottom like the old series and get the toe kick off first. Then remove or back off some screws at the base of the front panel and then compress the top springs to release the panel. Here are some old school pix
Posted on Sep 11, 2009
  • 45 Answers
SOURCE: Maytag Model...SAV205DAWW leaking water at bottom
there could be 2 things that i know of
first one is that someone bended the door to much and the joint's are eather lose or out of place
the second thing is that the door sealing rubber is out of place, you need to putt it back to place
Posted on Dec 27, 2009
What is the position of the belt on a Maytag Legacy SAV205DAWW? On the right or left of the idler pulley?
Sounds like the pump pulley is not in the rotation. Since there's only 2 options if its not working on the way you have it now, it must be the other.
Aug 31, 2014 | Maytag Washing Machines
Is it always necessary to purchase a new pump when replacing the belt on top load Maytag Washer? Model No. SAV205DAWW
Not necessary, unless you are suspicious for a problem pump. Or if want to avoid another problem.
Otherwise you must not do it.God bless you
Oct 16, 2012 | Maytag Washing Machines
My husband installed a belt in our Maytag washer model #sav205daww. when I went to use it it filled with water and didn't stop, it overflowed. Any ideas what might be wrong?
He could have pulled the small hose off that connects to the water level switch.
Or sediment could have shifted when he tilted the tub. Check that hose for secure connection and blow threw it to move the sediment and then pump out the water so that the pressure can build once again from the water level switch down to the base of the tub. themobilian_2693.jpg
Jul 27, 2011 | Washing Machines
What water pressure is requred for the Maytag frontload washing machine model MAH5500BWW?
The average water pressure that Mayteg has required was anything over 35psi minimum and 120 maximum?
Dec 28, 2010 | Washing Machines
Leaking watermodel sav205daww code1241b5
A hose has a leak. Remove the top panel and search all hoses for a wet area surrounding it
May 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Dec 27, 2009 | Maytag SAV515DE Top Load Washer
Remove the front of the washer to get at the water pump sav205daww
Sep 11, 2009 | Maytag Legacy Series Top Load Washer
In my mayteg washing machine it not spining and olso it stop just before throw water out .in another words it not finish the washing cycle and live the water in the washer
drain pump is jammed (you can manually try and turn it backwards first then forwards to unjam junk that may be stuck in it) it should turn freely ...less likely is the timer depending on how old it is.
Aug 16, 2009 | Washing Machines
Mayteg model DE313 clothes dryer that stopped drying clothes.
That is a very accurate assessment of the problem. Check the element for continuity between its two contacts. If there is none, replace it. If there is, look for a fuse on the side with two wires going to it. Test it for continuity. If there is none, replace it.
Jul 21, 2009 | Dryers
Maytag washer very noisy on spin cycle. Model no SAV205DAWW
check the pump for foreign object if nothing in the pump then you have a transmission problem
Apr 21, 2008 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
