Question about Drills
Hilti tm8 how to tighten chuck?
How do you tighten the chuck on a hilti tm8. I can't seem to tighten mine.
3 Suggested Answers
  • 123 Answers
SOURCE: need a new chuck for
The TM8 was only manufactured from 1984-1986. Parts have not been available in around 15 years. The TM8 had HIlti's version of the Joacob's chuck. It tightened the opposite way from a standard chuck. It had a tendency to fall apart and come off.Hilti revised the chuck two to three times but eventually did away with it after three years.
You might be able to find one on Ebay.
Posted on Sep 24, 2011
  • 20 Answers
SOURCE: I have a tm8 hilti hammer drill the chuck seems to be unscewing from the spindle how do i take it off
Most chucks have a screw down inside the middle to lock the chuck on. Sounds as if that screw is loose, it should be a lefthand screw. once that screw is removed you can unscrew the chuck by putting an allen wrench in the chuck and hitting it with a hammer to loosen the chuck.
Posted on Feb 08, 2012
Hilti chuck won't turn
inside the chuck you will see a screw, remove the screw and chuck . A small punch with minimum forced with a small hammer to move the chuck dogs toward the end on the chuck . The chuck was opened to far and is a mechanical bind ..
Jun 30, 2012 | Hilti SFH 18A CPC Hammer DrillDriver
Feb 08, 2012 | Drills
Need a new chuck for a tm8 hilti drill
Sep 18, 2011 | Hilti Drills
I need a new chuck as mine has lost bearings and wont hold a drill bit
I would suggest going to Hilti.com or calling them direct at 1-800-879-8000 for the replacement part and nearest center.
Oct 04, 2010 | Hilti Drills
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
The chuck on my old Hilti TE 60 is stripped.
Are you talking about the cap nut that threads onto the chuck? It is very rare that it would strip out. Word of warning if you do find one and thread it back on. You need to have a chisel in the chuck and have the chisel end locked in a vise. This protects from breaking the gear housing on the inside where the shift dog rides up and down.
Those parts are no longer available but you can still find some used on Ebay. Also the TE-72 used the same chuck parts.
Apr 27, 2010 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
How to replace the chuck on a hilti te10
The complete chuck is not easily replaced. It you stick an SDS+ bit in the chuck and it seems to fit tight without much wiggle then the chuck can be replaced without taking the tool apart. The rubber cap on the end will just pull off. Next the locking collar with the annular spring will come off with the out side sleeve. Underneath is the guide tube with two enlongated rollers. The locking collar should have a ball bearing underneath it that locks the sleeve in place. Usually the roller bearings or ball bearing are missing.
Mar 14, 2010 | Hilti Drills
Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Feb 27, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
HI I AM USING A HILTI TE16c AND THE HEAD WHERE YOU PLACE THE DRILL BIT OF THE DRILL HAS FALLEN OFF CAN YOU ADVISE HOW TO PUT IT BACK ON
this is an easy fix. it designed to come of easily and can fall off if you dont tighten the side handle. the chuck has a quick release mechanism. place the chuck onto the machine as far as you can. it wont go on all the way. simply pull back the black collar on the chuck toward the front of the chuck and push the chuck on the rest of the way.
to ensure that it is on correctly, turn the chuck by hand until it locks into place.
Hope this helps.
Aug 15, 2009 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Drills Logo
121 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
