Question about Ovens
Door hinge pulled out on one side, other hinge is fine. does not appear to be broken, but won't go back in slot.
Jenn-Air Model PRD3630NP
SOURCE: oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Posted on Jan 18, 2008
lsteward68
  • 331 Answers
SOURCE: My oven Door fell off. it is a Jenn-Air JJW9530C
This is a known issue. The model number is JJW9530C. I have been browsing the internet trying to find stronger hinges but with no luck. It seems there are a lot of unhappy Jenn air owners. You are correct in your assumption that the door is to heavy for the hinges. I will post the websites for your review
http://www.ovensworld.com/jenn-air-jjw9530c-expressions-collection-electric-single-oven.html
Maybe if I could see the hinge I could fabricate a stronger stainless steel one for you
Posted on Apr 27, 2009
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Posted on Aug 06, 2009
mc1bean
  • 3053 Answers
SOURCE: Having a problem installing oven door on a 27"
Hello, gerard..... Take off inner screws first to free up tight gap, then put in.
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
mc1bean
  • 3053 Answers
SOURCE: How do I remove the door to my Jenn-Air wall oven
Hello, marslyn
Thanks,Mike
I need the Start Amprege for a Jenn Aire #WW30430P
phone jen air tech support daytime Eastern Standard time:
1-800-JENN-AIR (536-6247)
Dec 20, 2013 | Jenn-Air WW30430P Stainless Steel Electric...
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
I need the Manual for jenn air w198-c
Hi, Sorry, but that's not a Jenn Air model number. Jenn Air ovens have 9-digit model numbers, e.g. JJW2530WS. Please reply to this message with the correct full model number and I will provide a download link to your manual if one is available. Regards, BElectric.
Nov 15, 2010 | Ovens
My Jenn Air oven digital display went out, what I
Apr 10, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Apr 27, 2009 | Jenn-Air JJW9530C Stainless Steel Electric...
No power - Jenn-Air JGW8130DDB
Also check for power at the wall plug. Fuse?
Apr 11, 2008 | Jenn-Air JGW8130A Electric Single Oven
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
