Question about Microwave Ovens
Microwave model 40185042210 won't heat
Everything appears to work but won't heat anything up.
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 02, 2008
rickzilla
  • 706 Answers
SOURCE: ge microwave won't heat everything else works fine
Hello t_sumner4756,
Everything else can work perfectly fine but if it doesn't generate microwaves to heat your food than it is not working ( you knew that anyway).. Unfortunately, and in most cases when you microwave stops working in that manner..the components at fault are either the Magnetron, Filament PS or a High Voltage Capacitor..What that means is that you are probably better off just replacing the entire appliance rather than attempting to repair it. If it is a year old or less, bring it back to where you purchased it and have them replace it.. I am sure that is not what you wanted to hear but when the cost to repair exceeds the cost to replace... it just isn't worth repairing.. Plus.. there is an element of danger associated with these kinds of repairs...
Regards,
Rick
Posted on Nov 22, 2008
djicenova
  • 319 Answers
SOURCE: Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Posted on Mar 21, 2009
bestdarngood
  • 3037 Answers
SOURCE: Microwave doesn't heat anything
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
ginko
  • 19396 Answers
SOURCE: Our Jenn-Aire Model JMV8196AAS Microwave is not heating anything.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
My whirpool microwave model wmh2175xvb1 Won't Heat
The problem is caused by the magnetron,"heart of the microwave oven" or the inverter board, if 7 years or less.
Apr 16, 2012 | Microwave Ovens
Model MW8999SB is not heating anything?
If the microwave powers up and everything appears to work then the problem is the magnetron, "heats food and is the heart of the unit" it is cheaper to replace the whole oven rather having it repaired.
Mar 03, 2012 | Emerson Microwave Ovens
Microwave not heating anything? everything else work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgshg
Jul 28, 2010 | LG LMH1517 1000 Watts Convection /...
Things are not heating up in the microwave
My GE Spacemaker Microwave oven does not heat up. Every other thing works. Model JVM1640
Jul 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Not heating up anything
Not knowing how much run time you have on the microwave , makes it hard to diagnose the problem but If everything appears to be working properly (as you describe) then you may have a bad/damaged or disconnected magnetron tube inside it. That kind of service should be done by professionals. Exposure to Microwave energy is not something you should mess around with unless you know what you are doing.. Good Luck
Aug 13, 2008 | Sharp R-820B Convection/Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
