Question about Music
Service center cebu philippines
Please help where to order AX-SYNTH RIBBON CONNECTOR as I want to Fix it myself.
2 Suggested Answers
  • 5603 Answers
SOURCE: my digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Posted on Sep 16, 2011
Hey, my synth fantom x6 now dead condition, Roland service center (kolkata) fix the problame. said it's flash rom chip is bad and its not avilable in market!! So..pls suggest me what I do??
Contact Roland directly. Speak to their customer service department in your country. I beleive this is the info-
http://www.dealerlocations.in/roland-dealers-in-kolkata
If it's just a parts availablitiy problem, remember that Roland is a world wide company. Contact Roland in other markets, starting close to you and expanding out. Somebody will have it. I'm in the USA and often source parts from Canada, for instance.
If the instrument is truely dead, you can always sell it for parts to other users. Ebay would be a good option.
Mar 24, 2016 | Roland Music
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
No sound third octave on kong trinity pro x 88 keys
You have a dislodged/dirty/broken ribbon connector coming from the keyboard. If you're not experienced in the disassembly and repair of your instrument, take it to a service center.
Jan 11, 2015 | Music
Korg m50 freezes, read in other forums that the problem may be to replace 2 capacitors, do anybody knows wich ones? or have a solution?
Hello, I own a Korg M50 myself and I had the same issue, its a quality control issue at their factory but, I may have a solution for you I found at a Korg forum. the issue is with these teeny cables inside the synth. you open the rear panel and firmly press each teeny cable into the terminals again and re attach and secure them firmly just finger push them all into their teeny sockets. this should stop the freezing I tried it the synth played all night with out freezing . I hope this helps other wise the solution with the capacitors is simple you order a new mainboard but they run about 400 plus. but try my solution it may work for yours this answer comes from a korg tech, he stated 90% of this freezing issue he has encountered has been these loose teeny cabling adapters, hope this helps, Have a great day..
Jan 27, 2014 | Korg M50 61-Key Music Workstation Keyboard...
My boy has an esp ltd ax 150 bass which has broken E strings at the bridge since new almost 1 a week the bridge was modified by a Luthier which worked for a small amount of time then the problem came
You friends bass has a burr on the saddle. take a small fine file and go along the pacth of the string...Go over the saddle and slowly file lightly..This should get rid of your problem...take it to a service center if you arent comfortable doing this
Apr 08, 2013 | ESP AX-414 LTD 4-String Electric Bass...
The roland d10 powers up but none of the buttons or keys work? the screen just says "roland d10 synth"? please help!
The unit name is part of the boot sequence, it should go beyond that and boot up completely. If it gets stuck there, there is surely some problem. Maybe a depleted internal battery, I don't know. Ask a local service center, maybe there's a combination of buttons you could check out while on the phone prior to bringing it in for repair...
Jan 07, 2013 | Music
My digitech rp 500 has power supply but it won't
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
When i am playing around with the synth parts, they all sound normal, until about 20 minutes after, everything on the synth side turns into these static kinda bass notes, really low and even all the...
There are many possibilities. One is static discharge... those nasty little sparks when we walk across the rug and get zapped... or we scoot a little in our chair... one''s that you can;t even feel can send electronics into a tailspin.
Another is a possible overheating someplace in the unit. However if it comes back immediately when restarting this is usually not temperature.
Your description of the problem MIGHT indicate a problem with the D-A or digital to analog convertor chip... if so it will require servicing, probably at the factory or having a board swap by a service agent.
Jan 18, 2011 | Korg Electribe Emx1sd Emx-1sd Mxsd Sd...
Where can I buy an LCD for my Alesis micron. I found someone who can do it but I need the LCD. There's this site that sells it but it's a little pricey and it has to be shipped. I live in the Philippines...
Many of the LCD's for these are rather special and as such are pricey. I would ask Alesis directely for parts source... You will likely have to live with whatever their recommended source charges.
Dec 04, 2010 | Alesis Micron Synth Keyboard
Problem using Kaoss Pad for synths.
Okay, maybe this is rude, but TOTALLY ignore Musicaldude's solution, if you haven't already found out the ugly way. Boosting the signal that goes into the KP will just make the input LED light up red and you'll hear digital clipping [gross] and eventually hit a ceiling of all-crappy-staticy-noise and no real guitar left. Having it in the FX loop, and the Headphone-out workaround are smart moves already, except the Headphone out adds noticeable noise/hum vs the usual outs. But to help close the gap between your guitar's volume and the miniKP's internal synths (and program 63 and 65's feedback noizes, which build up even louder than the synths) unplug one of the RCA plugs from the KP's OUTput, pick one, left or right, whichever. You'll notice this gives you a guitar volume boost. BUT its still not enough...the synths and 63 and 65's feedback are still speaker-blowingly loud. Check the manual, it says you can adjust the wet/dry volume by holding down Tempo and Preset A together, then turning the knob and picking 1 thru 99. Make sure you're on the synth setting you want to use already. Do this thing. Play the synth with your finger, while you lower the number with that knob. Stay around 50 if you've got the one RCA plug dangling, around 20 if both are in. Whatever you think matches your usual playing volume. When its where you like it, hold the A or B button (wherever you want to save this) down and click Hold, this will save it onto that preset button. Now from now on, NEVER use 63, 65, or the synths if you're on whatever preset you DIDN'T just save. i.e. If you chose preset B, from now on you can just tap preset B and it remembers your volume adjustment from before, voila, normal-volume touchpad synth. But go back to preset A for every other effect, or you'll barely be able to hear the FX. KORG should've given us more preset buttons to save onto. Godspeed. I've never seen this site before, but I have this pedal, and experienced the same b.s. myself. Now I'm down to one preset button and quick knob-turning. Whee.
Aug 07, 2008 | Korg Mini Kp Kaoss Pad
Music Logo
12 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
